Please forgive me if I missed a thread already covering this question previously. I am using an iMac which has Toast 15 installed which is a burning/dvd/blu-ray burning solution. I use software called iSkysoft media converter deluxe and have yet to receive an answer on the question of if it is possible to tweak settings to create the .mp4 AVC format file from an existing H.264 .mp4 AAC. The software approach in media converter is to allow you to select an option for example MP4 in the settings it only shows the ability to create AAC as part of the format. Anyway the reason I ask is Toast will transcode the video file (between 1.3GB and 1.4GB each) prior to the burning process. What are other software options to transcode the file format from the one into the other prior to burning the actual blu-ray recordable? I also can run windows 10 on the mac should the tool require it.
In the attached screenshot you can see some of the video formats you click after adding a video. It does scroll right or left depending on position.
I know this process takes a while just looking for something that may be more efficient in the process making it a little quicker to get the transcoding done. Computer specs are intel i5 quad core 24GB memory with standard 1TB hard drive as well as a 3TB external USB. Not great for this kind of thing but it will work for now.
Thank You,
MelRay
Converting from MP4-AVC to AVI-MP4(xvid)
By GruntVidStar in forum Video ConversionReplies: 24Last Post: 23rd Apr 2014, 16:34 -
Can't open .mp4 AVC/AAC video in Virtualdub
By sum_guy in forum EditingReplies: 4Last Post: 27th Feb 2014, 18:04 -
How to change .flv (Video:AVC Audio:AAC) to .mp4 without converting
By massafera in forum Newbie / General discussionsReplies: 12Last Post: 27th Feb 2014, 15:27 -
Editing MP4 files with H.264 (AVC) video and AAC audio
By Ahari in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2012, 17:30 -
MP4 w/ AAC ---> MP4 w/Compatible Audio
By NotSoEasy in forum Newbie / General discussionsReplies: 3Last Post: 26th Aug 2011, 16:41
