I had a sony 3D t30. It had broken and send it to sony and they fix free a few years ago. I was out of country on business. Camcorder broke with wife she took it in and the guy told her it would cost $800. Seems crazy so she said no brought it home thru it in garbage with sd card . She went out an bought new one. I had downloaded most stuff on our mac but cant find all the files. I would usually transfer from card or HD to mac, then convert to mov file of mp4. What is the best program to see if they are hidden on mac still. and are they raw files or video.
they were usually avchd files. originally. If they are raw files can you tell what they are before converting as there were lots of vids. any advice would be great. I know there are some files of kids missing.
sorry if wrong forum
Results 1 to 10 of 10
Seems the proper forum. The MAC users here may take a day or two for suggestions, so stand by...
Since the files should be rather large I would probably simply search for files with a min&max size inside a defined time frame and look through those.
there should be quite a few web sites with infos how search for files on a mac:
http://osxdaily.com/2015/08/03/find-specific-file-type-formats-mac-os-x-search/
http://www.cultofmac.com/273170/make-spotlight-sing-use-dates-search-files-os-x-tips/users currently on my ignore list: deadrats, Stears555, marcorocchini -
I don't know much about computers , these files were all deleted once they were put on the Mac . I put them On the computer then converted and trashed. So I don't know where to look
Ahhh,.. you deleted them. Then you either are lucky and they are still on the hdd or the place on the hdd got overwritten by other data. (especially if you are still actively using that hdd)
-> what you need is a data recovery program for macusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Yes there are lots but they will do free scans , but are expensive to see the files . I didn't know if some are better than others . And if they find raw data. Does that mean they are done for good etc
If the data got overwritten by other data the data can't be retrieved.
-> Personally I would try something like TestDisk (http://www.cgsecurity.org/wiki/TestDisk)users currently on my ignore list: deadrats, Stears555, marcorocchini -
Is it user friendly ,I k ow very little about computers . I just want it to look for that specific file type .
may be you can try this data recovery program for mac
Help retrieving a deleted video/fixing corrupted mp4
By Florio13 in forum Newbie / General discussionsReplies: 9Last Post: 14th May 2013, 02:03 -
Retrieving an accidentally deleted title
By vcats in forum Authoring (DVD)Replies: 1Last Post: 18th Dec 2012, 19:55 -
Retrieving AVI video after deletion and overwriting
By Jongi12 in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2012, 11:11 -
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
question about retrieving my HDD data? might be dead?
By NaHLiJ in forum ComputerReplies: 7Last Post: 28th Nov 2011, 08:01
