So my Courage DVD has an intro that has 8 pixels of black borders to the left and right..and then a main episode that fills the frame entirely.
How would I go about fixing this? I cropped the intro's 16 pixels..but now the frame size DOES NOT MATCH the DVD episode.
Should I just retain the black bars or stretch out the frame size of the intro to the size of the episode (which had no black borders and filles 720x480)? I feel like doing the latter...but then the aspect ratio would not be correct - would it?
Why do you think you have to "fix" it?
Is the AR off in the first place?
If the AR is correct, then yes, stretching it would distort the AR a bit.
Most people don't care about borders, especially if they are there for a reason. Some people don't care about minor AR distortions. Some people do other things like fill in the borders with something like a mirrored edge or other edge fill techniques -
You could keep the aspect ratio correct by cropping the 8 from left and right, then ~6 from top and bottom, followed by a resize to 720x480 for that intro part. But, like pdr, I'm not sure I'd bother.
Thank you everyone. I will leave it a bit distorted. Again not sure I want to take away any actual picture data just to have correct AR. It's unrecognizable (not like they're wide as a sandwich or anything).
Change aspect ratio or frame size of video without adding black bars ?
By Rhlsg in forum Video ConversionReplies: 6Last Post: 20th Jun 2013, 22:09 -
Why do most people crop out the black bars when ripping a DVD?
By KyleMadrid in forum Newbie / General discussionsReplies: 38Last Post: 22nd Feb 2013, 03:53 -
Black bars on sides of dvd recordings
By PeterDuggan in forum Newbie / General discussionsReplies: 29Last Post: 20th Oct 2012, 16:51 -
Need help with Dvd Architect black bars when I burn
By imazephed in forum Authoring (DVD)Replies: 0Last Post: 8th Sep 2012, 11:31 -
Can I remove black bars (top and bottom) when backing up my dvd's?
By jammiev in forum DVD RippingReplies: 10Last Post: 17th Jan 2012, 13:19
