Results 1 to 15 of 15
  1. I have some mkv videos and i want to convert them in to avi because its easier to burn in/hardcode subtitles but a conversion means that theres quality loss.
    What program do u suggest me to use to covert my videos with the least quality loss?
    Thanks in advance.
  2. i want to convert them in to avi because its easier to burn in/hardcode subtitles
    Where did you get that idea?
    But hardcoding subtitles require a re-encoding. You could use this or tell your final goal.
  3. Originally Posted by videobruger View Post
    sorry i dont know much i just think there are many programs to do that in avi videos instead of vidcoder which was also causing me a problem using and reading Greek subtitles. But anyway, i will give it a new try and tell u
  4. What format is your subtitles? .srt? If so make sure to use UTF-8 encoding.
  5. Originally Posted by videobruger View Post
    yeah its .srt and yes i used utf8 during encoding (i tried today)
    but the greek subs cant be showed even after choosing the language from the list.
    But the dots in the end of the sentences and the numbers(if there are any) are being displayed normally...
  6. cant be showed
    You're hardcoding (burn-in) right?
    the list.
    What list?
    Attach an example of hardcoding greek UTF-8 srt subtitles with Vidcoder. (I don't understand Greek)
  7. Originally Posted by videobruger View Post
    cant be showed
    the list.
    What list?
    yeah im hardcoding.
    im reffering about the list in vidcoder when u choose subs, language and type.
    i choose greek and utf8 and still no results. but the numbers, commas, dots and the rest symbols are being displayed..!
    example:
    Breaking Bad s01e04 720p BRrip - Chapter 1.mp4
  8. Oh, that list. It's just a meta-tag for info but otherwise without practical importance.
    It look to me it's wrong encoding. Could you attach your subs?
  9. Originally Posted by videobruger View Post
    here:
    Breaking Bad s01e04 720p BRrip.srt
  10. This is not UTF-8 but ANSI encoded.
    And looks like this
Name:	Screenshot - 8_12_2016 , 9_16_46 PM.png
  11. If it's readable to you in Notepad save it with UTF-8 encoding
  12. Originally Posted by videobruger View Post
    And looks like this
    [Attachment 38138 - Click to enlarge]
    okay so i must choose ansi in vidcoder or go in srt and save as utf8? or what?
    edit: its readable to me, no symbols like ur screenshots.
  13. I would recommend to save with UTF-8 encoding. Much more univeersial.
  14. Originally Posted by videobruger View Post
    yeah bro that worked! I saved the file and now the subs are embed and readable. I just want to have embedded subs and my dvd-player (on tv) to be able to read them as well. so vidcoder can do that job, right?
  15. dvd-player
    ?? Does it support Divx files or do you need a Video-DVD?
    Vidcoder can hardcode the subtitles to a MP4/MKV file with different video codecs.
