Hello people from VideoHelp,
I got a challenge that I need to conquer. I have a recorded footage (of myself) with a normal background (some plants, a couch and a TV).
I want to remove the background completely. I tried all different methods but the best way seems to me to export all frames into JPG and then use photoshop to cut the background out leaving me alone...
I have successfully done so but now I face the issue that when all frames are put together... they are not smooth... the edges change slightly frame by frame. I use Sony Vegas to edit the videos.
Is there an easy way to fix this or make it smooth?
Much appreciated.
EGAH
Works for me...Code:
@ffplay -i %1 -an -vf hqdn3d=luma_spatial=16:chroma_spatial=16:luma_tmp=8:chroma_tmp=8,format=pix_fmts=rgb24,colorkey=color=0x00D800:similarity=40/256:blend=7/256,alphaextract,colorlevels=aimin=127/256:aimax=129/256
photoshop can be use to edit video directly (so you can see frame to frame changes and fluctations more clearly and make adjustments) . But it's probably faster/easier to rotoscope in after effects in the first place. That's how you make it smooth.
Reshoot it, and this time, use a "Difference" blend mode to subtract the background. You'll need Vegas PRO.
Tip: Having a "clean" background "plate" is the key to success here.Last edited by budwzr; 12th Aug 2016 at 09:10.
Green screen after trimming an mp4
By storrm in forum Video ConversionReplies: 1Last Post: 1st Oct 2014, 09:26 -
Green Screen and Screen Flickers On And Off
By Teac23 in forum ComputerReplies: 2Last Post: 9th Jul 2014, 10:57 -
Green Screen Help!
By billyjb26 in forum EditingReplies: 7Last Post: 14th Mar 2014, 16:18 -
Tutorial for Green Screen with Avisynth?
By vidvidhh in forum EditingReplies: 17Last Post: 22nd Jan 2014, 17:10 -
Videoredo green screen
By JackDanielZ in forum EditingReplies: 2Last Post: 16th Jan 2013, 07:22
