Hello
I encode videos with low bitrates (980). I normally get 300fps when --direct is 'spatial' but when i change it to 'auto' in some videos it uses 'temporal' mod and slow downs to 250fps.
What is difference between spatial and temporal mod?
Does it have a BIG part on quality?
p.s: sorry for my bad English
I use Megui x264
x264 settings
program --level 4.1 --pass 2 --bitrate 950 --stats ".stats" --threads 16 --deblock -1:-1 --keyint 240 --ref 5 --qpmin 10 --qpmax 51 --vbv-bufsize 25000 --vbv-maxrate 20000 --me umh --direct auto --trellis 2 --psy-rd 1.0:0.15 --output "output" "input" -
I'm not sure if a 50fps slowdown is unexpected. "Spatial" means it's searching in the same frame. "Temporal" means it's searching adjoining frames. "Auto" means it'll do what's working best.
I tried a quick test. Only 2000 frames and a standard definition source (and my PC is slow) with the rest of x264 setting the defaults.
Spatial: 246 fps
Temporal: 235 fps
Audio: 233 fps
Not a huge difference but it'd probably increase a bit at higher resolutions, if there's a lot of motion (my test sample didn't have a lot) and when using --me umh (compared to --me hex).
x264 Mediainfo to MeGUI x264 Settings
By Arugen in forum Video ConversionReplies: 2Last Post: 13th Aug 2015, 02:14 -
MEGUI + x264 settings
By Cunhambebe in forum Video ConversionReplies: 41Last Post: 18th Apr 2014, 06:14 -
show x264 command line output when using megui as x264 gui
By codemaster in forum Video ConversionReplies: 4Last Post: 12th Mar 2013, 11:35 -
*.avi files as direct x264 input
By turk690 in forum Authoring (Blu-ray)Replies: 5Last Post: 23rd Jun 2012, 11:43 -
By shagratt71 in forum Video ConversionReplies: 0Last Post: 1st Jan 2012, 05:59
