Just bought a DVD writer to back up my own DVD movies. For instance, I would like to backup 4-5 movies per blu ray.
Do you have a guide? software to do this? any freeware way to do this?
thanks in advance!
Some people have mentioned multiAVCHD (free) or DVDFab DVD to Blu-ray Converter (not free) for doing this. You won't be able to keep the original menus.
I hope you meant to write "Blu-ray burner". DVD writers cannot burn Blu-ray media.Last edited by usually_quiet; 9th Aug 2016 at 21:16.
BD Rebuilder can do this, but I would use a couple of other tools as well. Decrypt the DVD movies and remove extras and menus by using MakeMKV on them. This will give you a MKV file for each movie. Put all four of these into one folder on your hard drive.
Then import the MKV files into BD Rebuilder by clicking File-->Import-->Video Files. Have your Output Target set to BD 25. BD Rebuilder will re-encode the movies to H264 and put everything in Blu-ray format. You'll have a very crude menu to select each movie. The whole process will take a considerable amount of time, unless you set the encoder to the High Speed option, and even then it will take hours.
Burn the output to a Blu-ray disc using ImgBurn.
If you'd rather not re-encode the videos and audio, things get trickier, but can be done. -
For multiAVCHD or other similar programs, go to their software page here and scroll down about half way and you should see a reference to some guides for the software.
For general guides, look to the upper left on this page under 'HOW TO' and you will see an index of all guides.
And for Blu-ray discs, I would only recommend Verbatim BD discs, such as: https://www.amazon.com/Verbatim-Branded-Surface-50-Disc-98397/dp/B00GSQ4DBM? -
thank you very much! I will test these options. Another question: a friend of mine told me that converting blu ray files to mpls and then burning them is another way...do you have any experience with this?
If you already have a bluray files, there is no need to convert them. "MPLS" isn't the video files, those are m2ts files.
> https://www.videohelp.com/hdGoogle is your Friend
Putting multiple DVD images onto single Blu-Ray disc?
By Super Warrior in forum Authoring (Blu-ray)Replies: 9Last Post: 12th Oct 2014, 16:59 -
video blu-ray burn to double layer DVD disc
By toomail in forum Video ConversionReplies: 11Last Post: 9th Jun 2014, 19:29 -
How to make multiple movies on 1 blu ray?
By Novakingwai in forum Authoring (Blu-ray)Replies: 6Last Post: 29th May 2013, 23:31 -
Burn mkv/whatever to blu ray disc playable on Vizio Blu ray player?
By Eric1987 in forum Authoring (Blu-ray)Replies: 3Last Post: 1st Dec 2012, 21:41 -
Multiple DVDs on a Blu-Ray Disc
By rstrom2008 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2012, 06:34
