The story.....
In the past ffms2 included a script for combining video and audio with FFmpegSource2(). I've pasted it below.
You could put the script in the Avisynth auto-loading plugin folder so the function is always available, but being a script, you can fiddle with the default values.
I'd like the audio to be automatically included when I use FFmpegSource2(). When the script below was running the show, changing "atrack = default(atrack,-2)" to "atrack = default(atrack,-1)" did the job. These days, the same functionality is included in the dll, but is it possible to create a simple auto-loading script that will change a default value in much the same way?
My current workaround is to change "function FFmpegSource2()" to "function FFmpegSource3()" in the script below and continue using it (with atrack,-1 as the default), so that way FFmpegSource3() opens the source with audio by default, while FFmpegSource2() from the dll doesn't..... for reasons I don't understand given the purpose of FFmpegSource2 is to combine the video and audio. Or is that a bad idea?
None of it's a big deal of course, but sometimes it's the little things..... and I'm curious. I might even learn something. Anyone know of a simple way to tell ffms2.dll I want FFmpegSource2() to include the audio by default?
Cheers.
Code:function FFmpegSource2(string source, int "vtrack", int "atrack", bool "cache", \ string "cachefile", int "fpsnum", int "fpsden", int "threads", \ string "timecodes", int "seekmode", bool "overwrite", int "width", int "height", \ string "resizer", string "colorspace", int "rffmode", int "adjustdelay", \ bool "utf8", string "varprefix") { vtrack = default(vtrack,-1) atrack = default(atrack,-2) cache = default(cache,true) cachefile = default(cachefile,source+".ffindex") fpsnum = default(fpsnum,-1) fpsden = default(fpsden,1) threads = default(threads,-1) timecodes = default(timecodes,"") seekmode = default(seekmode,1) overwrite = default(overwrite,false) width = default(width,-1) height = default(height,-1) resizer = default(resizer,"BICUBIC") colorspace = default(colorspace,"") rffmode = default(rffmode,0) adjustdelay = default(adjustdelay,-1) utf8 = default(utf8,false) varprefix = default(varprefix, "") ((cache == true) && (atrack <= -2)) ? ffindex(source=source, cachefile=cachefile, \ indexmask=0, overwrite=overwrite, utf8=utf8) : (cache == true) ? ffindex(source=source, \ cachefile=cachefile, indexmask=-1, overwrite=overwrite, utf8=utf8) : nop v = ffvideosource(source=source, track=vtrack, cache=cache, cachefile=cachefile, \ fpsnum=fpsnum, fpsden=fpsden, threads=threads, timecodes=timecodes, \ seekmode=seekmode, rffmode=rffmode, width=width, height=height, resizer=resizer, \ colorspace=colorspace, utf8=utf8, varprefix=varprefix) a = (atrack <= -2) ? blankclip(audio_rate=0) : ffaudiosource(source=source, \ track=atrack, cache=cache, cachefile=cachefile, adjustdelay=adjustdelay, \ utf8=utf8, varprefix=varprefix) return audiodubex(v,a) )
Results 1 to 1 of 1
Setting Movie Only Bd Audio and PGS Subtitles to Default ON when not Reenco
By ScorpionStingz in forum SubtitleReplies: 0Last Post: 7th Nov 2015, 21:20 -
Default Avisynth script for Ripbot?
By lonrot in forum Video ConversionReplies: 23Last Post: 3rd Jul 2014, 04:12 -
megui adds colormatrix avs plugin by default
By codemaster in forum Video ConversionReplies: 2Last Post: 12th Mar 2013, 14:50 -
Setting default audio track with TsmuxeR
By bruce73 in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 08:24 -
Setting Default Streams
By grannyGeek in forum Authoring (DVD)Replies: 9Last Post: 15th Oct 2011, 14:53
