  1. Member ahhaa's Avatar
    Feb 2005
    Michigan USA
    I just got a phone that will let me do hyperlapse and timelapse; which are a lot of fun but take time to do.
    This's brought a recurring problem I've had to a much higher priority.
    I've got an older Lumix FZ7, a Canon 300HS, and my Droid Turbo, which is what I'm using now.
    All will shoot video, and the same problem has occurred on each; which I attributed to a faulty SD card.
    The video files, whether normal or TL/HL, will play back OK on the originating device with it's own software.
    If the files are copied to a PC or flashdrive, and then played back with VLC, they will sometimes start with a black screen and recover, or just become a show of giant grey and black pixels. This part is repeatable, but which vids become defective seems completely at random.
    Thing is, I can't blame VLC because it never does this fail with downloaded MP4s, or really anything else.
    The output I'm most concerned about is the Droid; the software I'm currently using on it is Microsoft's Hyperlapse Mobile, tho I have tried other apps like A Better Camera and TimeLapse from the Playstore...
    Any ideas on what the problem might be? Can't be USB cables, SD cards, etc because they are all different on the 3 devices...
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Have you checked one of the files specs using MediaInfo?
    Cameras and phones don't always use standard video specs, even if they do use a common container.
    Google is your Friend
