Hi
how could i set no screen saver during play at "Awesome Video Player"?
(is there a way to access the settings there? or all you got is the simple menu?)
Depends on the OS on that computer. But generally with MS, go to 'Control Panel>Personalization' .
On the lower right on that page should be an icon to turn off the screen saver, if it's part of the OS. -
Should you have to disable the screensaver? Some players, such as audio players, have an option to disable it and/or to prevent the monitor from going into standby mode while they're running, but does the screensaver activate while the player is displaying video?
the screen saver activated while playing, yes
i want that the player will turn is off only while playing
Windows 7 video player that can save URL videos with applied video effects?
By coolvibe in forum Newbie / General discussionsReplies: 7Last Post: 13th Jun 2016, 17:52 -
Video Conversion/Compatibility Question flv->Win Media Player, Mac Player
By charlestek in forum Video ConversionReplies: 7Last Post: 18th Nov 2014, 15:05 -
Which things make x264 video look awesome ?
By PrinceSwaraj in forum Video ConversionReplies: 1Last Post: 15th Sep 2014, 11:26 -
Video Files Not Showing up on xbox using System Video Player
By isisism in forum Software PlayingReplies: 2Last Post: 10th Feb 2014, 01:41 -
Resize a video to fit an in car video player
By _oldnich in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2013, 15:30
