So, newbie, yea i know, been trying to do this on my own without help but after several trys an different softwares used, I've had to toss 5 or 6 failed BD-R's in the trash, and hoping maybe someone can help
1st off, I have the Hauppauge 1212 PVR, which so far i've used to create 2 video files in .M2TS. Now I recorded them in 1080i which as I understand it, the Hauppauge doesnt do very well when it comes to trying to convert it to BDMV an rip to BD-r. Each file is about 10 gigs+
I could care less about editing the files, just want the footage onto disk in HD, preferably blu-ray, but if there is another option to burn onto a BD-r and still have it play on a Blu-ray player and look like Hi-def, great, LMK.
What i've tried:
Have multiAVCHD and all its associated necessary files (avisynth, ffdshow, etc). I've had 'some' sucess converting the files to BDMV, The encoding takes a lil while, 4-5 hours. 1st time i got an error on menu creation, but it seemed to finish sort of. I tired burning but imgburn hit me w/ an error at 97% complete, i made 2 other attempts but i messed up somehow cuz they came out w/ no video. I tried re-converting it again and it seemed to have worked, but i also set it to burn to imgburn when done an that didnt work, it threw another error: (RT) Application "C:\programfiles\imgburn.exe" cannot be executed - Line 36161 and when i tried burning the created BDMV/Cert folders w/ IMgburn, well it burns, but when played, theres nothing that plays, no video.
I've been kicking around the idea of re-recording the footage at 720p an re-try, which i guess is really my next thing to try.....ok i've now got a video recorded in 720p, still having issues. multiavchd complaining about: (RT) Invalid array index. Array is empty - Line 35926
Warnings:/errors for this compilation Compilation does not contain...................then it closes.
I've tried txMuxer, but , i get errors. It first says: Unsupported format: Some tracks not recognized. This tracks was ignored. File name C:myfile.M2TS when just trying to load the file. Than when mux'ing it gets to 52% an fails on error: 1073741819
Tried to use the software that comes w/ by BD Burner: Cyberlink Media Suite, Cyberlink PowerProducer, it proceeds to burn to disk but, ends w/ an E0...somethin error, which when i googled the error, said it was a low memory error, so i re-set it to burn at 2x, the slowest speed, but still got the same error.
I've d/l'd Arcsoft Showbiz software, but it doesnt seem to author in BDMV, nor does it seem to re-encode either. Haven't tried burning a file w/ that as that would require another BD-r since the files are too large to fit on anything else, to include DVD DL. Theres been other software i've d/l'd an tried but none them seem to author in BDMV (videoredo comes to mind).
Thinking about trying: TMPGEnc Authoring Works 5, as it has a free trial. Certainly don't want to buy any software if its not going to work anyway.
Starting to run out of ideas. There are 2 other formats supported by the Hauppauge, .ts and mp4. Could try those i guess. I may update/edit this post w/ other pertinent info that i can think of.
	Ok, I finally have some success.
 I recorded just 5 mins of video using a different software. Arcsoft Showbiz software, threw that video into tsmuxer and got no errors for a change. muxed sucessfully, and burned w/ img burn on a standard DVD a Blu-ray video and viola, I'm watching an HD video on my blu ray player.
 So at least I've got an avchd video on disk. I'll keep playing with it.
	Welcome to our forums.
 Sometimes it takes a day or two to get answers. Stand by...
	Thanks for the welcome, I've browsed thru this forum a lil bit over the years but, finally had a need to register and ask a question.
 Success!
 So in summary, for future readers of this thread.
 I downloaded Arcsoft Showbiz software (google search will show u how to do that for FREE)
 used that software to capture the video from the SAT box, and not the software that came w/ the Hauppauge 1212. (although I may try to use that software again an choose .TS to see if that makes a difference, so far I've only tried .m2ts)
 Used the .TS format for capturing the video, which is labeled as AVCHD.
 Once done, u can use either 'tsmuxer' or 'multiavchd', the later of which creates a menu for Blu-ray, the former, just a playable video.
 the processing/re-encoding only took a few minutes.
 than ImgBurn in Build mode to burn the BD-r
 I have my SAT box output set at 720p, and the .TS file is apparently an mpeg2 video file, but the finished product still looks like HD programming to me.
 Still need to play around w/ creating my own menu's, instead of the default ones that come w/ multiavchd. and I may try the .mp4 video capture too, see how that works out. But at least I finally have successfully created Blu-ray disks like I wanted.
	You might find this thread useful:
 https://forum.videohelp.com/threads/376006-BDMV-Authoring-Workflow-Guide
	MPEG-2 TS is only a description of the container type. The video inside is AVC (H.264). The HD-PVR 1212 cannot capture video as MPEG-2. It has a H.264 hardware encoder.
 That being said, MPEG-2 is certainly capable of HD resolutions and is also permitted by the Blu-ray spec, although it isn't used often as H.264 because it requires more disc space to provide the same apparent quality.Last edited by usually_quiet; 19th Aug 2016 at 10:46.
  Blu-ray rip to m2tsBy DrReaper in forum Blu-ray RippingReplies: 16Last Post: 11th Feb 2015, 19:34
  Software to read a DVD disk and convert it to a Blu-Ray diskBy andy jackson in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2013, 20:32
  over sized blu ray 3d, can i make BDMV and burn a BD-DLBy samultoe in forum MacReplies: 15Last Post: 10th Apr 2013, 23:49
  BDMV Folder from fullhd camcorder can not play with Blu-ray player.By wisitch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th May 2012, 05:57
  M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray PlayersBy messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
