  1. Facts:
    - I recently acquired an XH-A1 Canon for college.
    - I used it to film a wedding recently, but I'm having troubles capturing and transferring it.
    - I tried using both Windows Movie Maker and HDVSplit .77 beta to capture and transfer it, but both times the files would say size of 0 bytes and wouldn't let me view them.
    - Also, something else notable is while it was capturing it through firewire, the preview screens for both capture methods were black.
    Any and all suggestions would be helpful.
    My preferred method would be to capture through Adobe Premiere 14, but I found out that my device isn't compatible.
  2. Member Skiller's Avatar
    Oct 2013
    Germany
    It might seem too obvious to ask but anyway, just to make sure: you are using the Firewire (IEEE 1394) port of the camcorder, right? And connected it to a Firewire port on your computer, right? No USB at all, right? USB on Camcorders is for photos only. You must use Firewire.
  3. Originally Posted by Skiller View Post
    That is a bit obvious of a question, but yes I am using Firewire hdv/dv port on my camcorder and firewire 6 point port on my computer. USB wouldn't work as you said.
    Aug 2010
    San Francisco, California
    Did you set PLAYBACK STD according to the instructions on Page 109 of the manual?
  5. Originally Posted by JVRaines View Post
    Yes. I have it set to HDV.
    Oct 2005
    666th portal
    when using hdvsplit with win7 or newer os you have to put it in a folder other than c:/program files(86) and then you have to run hdvsplit as admin or even better set it to always run as admin by right clicking on hdvsplit.exe select properties/compatibility and change the privilege level to always run as admin. click apply and ok. otherwise it doesn't have os permission to write files.
