  1. DECEASED
    Jun 2009
    Heaven
    When I use the "Open with" entry in Windows Explorer context-menu,
    I am greeted with this annoyance:
    USA
    Which version? I'm using 0.7.79, not the newest and I haven't seen that.
    I normally use the 'MediaInfo' entry from the context menu.
  3. DECEASED
    Jun 2009
    Heaven
    ^ Version 0.7.85.
    I haven't checked the latest version either
  4. DECEASED
    Jun 2009
    Heaven
    UPDATE:
    version 0.7.88 is broken as well , BUT
    I cured the disease with Resource Hacker
  5. Batch script can be created, having it it on desktop for example, using Mediainfo command line version, ( Mediainfo CLI), and just dropping video on that icon:
    @echo off
    setlocal
    SET Mediainfo=C:\tools\Mediainfo CLI\Mediainfo.exe
    SET temp_folder=C:\temp
    if not exist "%temp_folder%" MD "%temp_folder%"
    "%mediainfo%" "%~1" > "%temp_folder%\mediainfo.txt"
    START  "notepad.exe" "%temp_folder%\mediainfo.txt"
    endlocal
    exit
    It can be modified to anyone's liking etc.
