Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 15 of 15
  1. Hi
    I'm trying to encode a 1080p video to 720p (x264 and x265)
    The source video is clean and doesn't need any debanding but output video is very dirty
    I use crf 24 for both x264 and x265 encodes.
    Help please
  2. Use 10-bit encoding with either encoder. Even with low bitrates you won't get banding.
  3. Originally Posted by -Habanero- View Post
    There is no "10 bit encoding" option in x265 setting (megui)
    Also i need to use 8 bit for some reasons
  4. Originally Posted by ben45 View Post
    You may consider adding grain/noise as a crude form of dithering to prevent banding however it will require higher bitrate as noise is not compressible.
  5. Originally Posted by ben45 View Post
    I use 10-bit x264 all the time in megui so the same should work for x265. There is an encoding option for 10-bit, it's -D 10.
    Your other option is deband post-processing during playback. ffdshow has it. There are avisynth scripts for debanding that you could also apply during playback and so on.
  6. Originally Posted by pandy View Post
    You're right. I can't use noise or grain because it will require higher bitrate.
    canada
    Use crf 22,crf 24 is a bit too low,you will see more artifacts at 24 since you want to use 8bit encoding.
  8. Originally Posted by johns0 View Post
    I can't use crf 22 because i need smaller file size.
    Is there any way to reduce banding on crf 24?(medium speed)
    May 2014
    Down the road, last house on the right
    You can try this: Find out what the bitrate you are getting at crf 24 medium preset using media info. Plug that bitrate into your encoder using a
    2-pass (slow first pass) and a slow preset. And try turning down the adaptive quantizing strength (aq=0.5 to 0.6). And for further improvement
    you can use tune grain and avoid larger file sizes. As for me, I use a crf of 18 or 17 when doing a single pass method for typical encodes.
    This method has helped me before with varying degree of improvement whenever I've encountered banding but felt I needed to control the
    file size. With this method you can also play around with adding some grain to act as dither as suggested in an earlier post.
  10. Originally Posted by Dougster View Post
    Thankyou
    Just now checked crf 24 encoded file bitrate. It's 813kbs! Re-encoded same file with 2-pass method and 500kbs bitrate and....... 2-pass killed %50 of bandings and quality is much better than crf 24!!
    2-pass encode speed is the only problem. it takes 2x realtime to encode a 720p and 4x realtime for a 1080p
    May 2014
    You're welcome. And yes, encoding time would obviously at least double. Patience is everything when dealing with video encoders.
    Jan 2007
    I never use crf greater than 20
    It's quality versus file size
    Which one is more important to you
    If your after a specific file size you have too live with the limitations of quality that it introduces
  13. DitherTools can help quite a bit. Start by sticking gradfun3() at the end of a script. I rarely encode without it. Admittedly I also tend to use lower CRF values, but it should still help.
    http://forum.doom9.org/showthread.php?p=1386559
    Even though technically it adds noise, I find if anything gradfun3() reduces the bitrate a little for a given CRF value. I'm not 100% sure why.
    Or DitherTools can convert to 16 bit, resize in 16 bit, then dither back down to 8 bit, in which case you probably wouldn't need to add gradfun3() to the script as resizing that way would be less likely to induce banding than 8 bit resizing.
    For the record, there's 8 bit and 10 bit builds of the x264 encoder, but only one x265 encoder. It can encode at 8, 10, or 12 bit according to the profile you set. MeGUI's x265 encoder configuration is as basic as it gets at the moment, but adding the following to the custom command line section will enable 10 bit x265 encoding:
    --profile main10
    http://x265.readthedocs.io/en/default/cli.html#profile-level-tier
    x265 also has an option for setting the output bitdepth (--output-depth) which is also the bitdepth it'll use internally, apparently.
    http://x265.readthedocs.io/en/default/cli.html#cmdoption--output-depth
    I don't use 10 bit x264 myself as hardware player support is fairly non-existent and probably always will be.
    h265 included 10 and 12 bit encoding in the spec from the get-go, so with any luck that'll be a different story... once h265 playback support is mainstream. Hardware player support for h265 is still pretty limited regardless of the bitdepth at the moment anyway, so if I was to use the x265 encoder I'd be pretty tempted to go straight to 10 bit.
  14. [QUOTE=ben45;2455279]
    Random noise is not compressible but pattern dither should be compressible better than noise or grain - problem is that i don't know any tool (perhaps except avisynth and mentioned dithertools by cretindesalpes http://avisynth.nl/index.php/Dither_tools - never tried zscale which is implemented in ffmpeg) that can provide for example YCbCr 6 bit pattern dithered over 8 bit YCbCr 420p - it is quite strange btw...
  15. Thankyou so much guys
    Seems i have to increase bitrate a bit
