Results 1 to 10 of 10
  1. I have a video file in which the audio is delayed by about 4 seconds. The audio starts too late.
    I tried various things according to this post: https://forum.videohelp.com/threads/346293-Insert-Audio-Delay-With-ffmpeg :
    • I tried to use avidemux, but no matter what value I enter in the delay box, the delay was STILL the same
    • I tried to use the following command: `ffmpeg -i test.avi -itsoffset 4.0 -i test.avi -map 0:0 -map 1:1 -vcodec libx264 -r 25 -b:v 1268k -s 512x368 -acodec copy audio_delayed.mp4` but still the delay was the same!
    • The only thing that worked more or less is to use kdenlive to split the audio and the video, shift it manually, repeat and repeat and render the video file taking almost 30 minutes of time. Its a 9 minute video, and all I want is to shift the audio wrt. the video...
    Is there anything else I can try?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Yes... AviDemux.
    The delay is in milliseconds, don't be afraid to use big values in there... +- 250, 500, 1000, 2000, etc etc.
  3. Thanks hech54,
    I already used values like 4000 ...
    Dec 2005
    Canada
    I tried your command on a video that was oos by 500ms and it made no difference.
    ffmpeg -i clip.mp4 -itsoffset 0.500 -i clip.mp4 -vcodec copy -acodec copy -map 0:0 -map 1:1 output_clip.mp4
    Then I used this command and it worked.
    ffmpeg -i clip.mp4 -itsoffset 0.500 -i clip.mp4 -vcodec copy -acodec copy -map 0:a -map 1:v output_clip.mp4
  5. What I get is just audio without video! And when I reverse the mapping I have nothing...
    Error message in the first case during playing (repeated hundred times or so):
    missing marker bit!
    MPEG: bad sequence header
    and during the conversion with ffmpeg I seen thousand of buffer underflow errors...
    I am also trying to use mpg file, maybe that play a role...
    Dec 2005
    Canada
    Using your script with my offset and map values, I had no problem.
    ffmpeg -i test.avi -itsoffset 0.5 -i test.avi -map 0:A -map 1:V -vcodec libx264 -r 25 -b:v 1268k -s 512x368 -acodec copy audio_delayed.mp4
  7. I got immediately the following error:
    [avi @ 0x3e4bf00] Invalid stream specifier: A.
    Last message repeated 3 times
    Stream map '0:A' matches no streams.
    ffmpeg:
    ffmpeg version N-80901-gfebc862 Copyright (c) 2000-2016 the FFmpeg developers
    built with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04.3)
    configuration: --extra-libs=-ldl --prefix=/opt/ffmpeg --mandir=/usr/share/man --enable-avresample --disable-debug --enable-nonfree --enable-gpl --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb --disable-decoder=amrwb --enable-libpulse --enable-libfreetype --enable-gnutls --enable-libx264 --enable-libx265 --enable-libfdk-aac --enable-libvorbis --enable-libmp3lame --enable-libopus --enable-libvpx --enable-libspeex --enable-libass --enable-avisynth --enable-libsoxr --enable-libxvid --enable-libvidstab
    libavutil 55. 28.100 / 55. 28.100
    libavcodec 57. 48.101 / 57. 48.101
    libavformat 57. 41.100 / 57. 41.100
    libavdevice 57. 0.102 / 57. 0.102
    libavfilter 6. 47.100 / 6. 47.100
    libavresample 3. 0. 0 / 3. 0. 0
    libswscale 4. 1.100 / 4. 1.100
    libswresample 2. 1.100 / 2. 1.100
    libpostproc 54. 0.100 / 54. 0.100
    Hyper fast Audio and Video encoder
    Dec 2005
    Canada
    Instead of using V and A in the command I used your line from the first post and reversed the map as shown below and it worked.
    ffmpeg -i test.avi -itsoffset 0.5 -i test.avi -map 0:1 -map 1:0 -vcodec libx264 -r 25 -b:v 1268k -s 512x368 -acodec copy audio_delayed.mp4
  9. Thanks for your help, now the render command work. But the offset between video and audio is still present. I chose a 4 second value(!) but still the audio is way before the video. Also changing to -map 0:1 -map 1:0 did not change anything ...
    Dec 2005
    Canada
    This worked for me.
    Audio leads video
    This file bbt.mp4 stream map showed 0:0 video 0:1 audio
    Add a positive value for audio adjustment (used mpc to get value)
    offset 500 ms will be applied to second file listed on command line (second appearance of bbt.mp4)
    On the command line...map now means something else :
    map 0:0 means first listed file on command line - keep video
    map 1:1 means second listed file on command line apply the offset to audio
    ffmpeg -i bbt.mp4 -itsoffset 0.500 -i bbt.mp4 -vcodec copy -acodec copy -map 0:0 -map 1:1 output_bbt.mp4
