Currently using Solveig Splitter to cut clips from my footage, but there doesn't seem to be a slow down/speed up option when I'm trying to cut clips. I don't want to watch the footagein its entirety again. Are there any video editors (preferably ones that allow you to open TS files) that can slow down/speed up footage?
Please do not suggest Sony Vegas or anything of that sort - I use that for the final product, and not cutting clips.![]()
Cutting clips has little to do with speeding up/slowing down. Those use interpolation - a whole extra level of complicatedness. Thus, requiring an NLE and not just a trimmer/joiner. You can't have your cake and eat it too.
Scott -
This makes no sense to me. I think you misinterpreted my post, though I probably could have done a better job in explaining my problem. When I cut clips, I rely heavily on speeding up/slowing down the video, so that I use my time efficiently. I don't want watch the full footage at normal pace, and that's why I rely heavily on speeding everything up. I have used MP4Cutter, which gives me this option (contrary to your opinion), and it has worked wonders for me. Only issue I have right now... is that I'm using large 1080 TS files, and that's the reason for my post.
If you're using Vegas to finish it's not clear why you need something else to pre-cut your clips.
Vegas has all the transport functions you are looking for (speeding up, fast scrubbing, frame by frame.) You can mark and subclip your selects and then edit from the subclips. This is a pretty standard workflow.
How to make a slow-motion fragment in VSDC Free Video Editor?
By Katty.Fine in forum EditingReplies: 2Last Post: 10th Jun 2016, 05:14 -
Slow down or speed up mp3
By jimmyy in forum AudioReplies: 7Last Post: 11th Mar 2016, 15:03 -
Slow Conversion Speed
By Gouranga Das in forum Video ConversionReplies: 5Last Post: 23rd Aug 2013, 12:47 -
How To Speed Up and Slow Down the Footage
By blewyn in forum EditingReplies: 6Last Post: 25th Jan 2012, 22:46 -
Win7: slow down dvd speed
By themaster1 in forum ComputerReplies: 4Last Post: 1st Jan 2012, 20:03
