Hi
What is the best Avisynth resize filter for these bitrates (H264) :
1800kbps?
950kbps?
500kbps?
Results 1 to 10 of 10
1800, 950, 500 WHAT
bps, kbps, Mbps
Also, what's the video format you're talking about? MPEG-2, MPEG-4 ASP, H.264, HEVC, VC-1,
or something else?
Anyway...
according to the documentation, the more a filter sharpens the image, the less the result is compression-friendly
So, for low bitrates, BilinearResize should be the "best" choice. -
There is no single answer for all videos. It depends on the nature of the individual video.
Generally, sharper resizing increases noise and detail and will require more bitrate. If your source isn't very sharp sharper resizing may look better. If your source is very sharp a sharp resize will create oversharpening halos. If your video has a lot of noise sharper resizing will increase the noise and require more bitrate.
A clean cartoon with a sharp resizer may look fine at 500 kbps. A grainy old movie will look pretty bad.
And, of course, you need to take into account the frame size and the frame rate. Large frame sizes and higher frame rates can require more bitrate.Last edited by jagabo; 6th Aug 2016 at 08:20.
Thankyou
Can i use psy-rd with Bilinear resizer to make picture semi-sharped?
Here's my profile setting
Source is not sharp at allCode:--pass 2 --bitrate 950 --stats ".stats" --deblock -1:-1 --keyint 240 --min-keyint 23 --b-pyramid none --ref 5 --chroma-qp-offset -2 --me umh --direct temporal --trellis 2 --psy-rd 1.0:0.35 --no-fast-pskip --qpmin 10 --qpmax 69 --output "output" "input"
Bilinear is a softer resizer so it will blur the picture a bit and reduce noise. If your video is noisy you should consider reducing the noise before encoding to save more bitrate. Yes, psy-rd sacrifices a little accuracy in order to gain a little more compression.
Oh
Do you know any filter that sharp picture like spline36?
Resized 1080p to 720p @ 950kbs
http://uploads.im/wVUuL.png
http://uploads.im/4I7qE.png -
To sharpen a video you use a sharpening filter and you don't rely on the resizer to do it for you:
http://avisynth.nl/index.php/External_filters#Sharpeners
I use LimitedSharpenFaster most of the time, others LSFMod, others something else. Sharpening makes a video less compressible and might, if encoding for the same file size, make the video look worse than if you hadn't sharpened at all. Just judging from the pictures (a poor way to judge a video), it doesn't need to be sharpened.
VirtualDub - bad resize filter
By ralf07 in forum Video ConversionReplies: 2Last Post: 30th Jul 2013, 20:41 -
Why/when to use codec friendly sizing in the VDub resize filter?
By brassplyer in forum EditingReplies: 2Last Post: 25th Oct 2012, 10:07 -
Best way to resize a video to 16:9?
By Dr Gonzo in forum EditingReplies: 5Last Post: 27th Jun 2012, 08:00 -
Megui Resize Filter
By xxxThiefxxx in forum Video ConversionReplies: 4Last Post: 18th Apr 2012, 23:00 -
resize filter in virtualdub for upsizing videos
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2011, 06:26
