hi guys
finaly i recorded and remove HDCP with spliter
ok now i have another problem
video quality is optimal in its best quality but record files are in 25 frame not 30 frame
can anyone help me for recording 30 fram avermedia ez recorder 130
thanks
I looked at the manual and found no settings available to adjust the capture resolution or frame rate. The EzRecorder 130 always captures at the same resolution and frame rate as the video it receives, unless the input is 1080p60 or 1080p50. In that case, 1080p60 is recorded as 1080p30 and 1080p50 is recorded as 1080p25.
i want record same frame but our channels satelite reciver are in 1080p 30 frame but ezrecorder record them 1080p 25 frame
and after i see the records files it is realy annoying for 25 fram like football matches
any way to fix it record same frame like satelite 30 fram/per second? -
Try update the firmware to last version.
Get here: http://www.avermedia.com/gaming/support_faq/ezrecorder_130
Try and reply.
Claudio -
The AVerMedia EzRecorder 130 manual lists the following HDMI input resolutions as supported: 480i/576i, 480p/576p, 720p (50 & 60Hz), 1080i (50 & 60Hz), 1080p (50 & 60Hz). Notice that 1080p (25 & 30Hz) is not listed.
Since 1080p (50 & 60Hz) are captured as 1080p (25 & 30Hz), it seems reasonable to expect that 1080p (25 & 30Hz) input could be captured as 1080p (25 & 30Hz) as well, but maybe that is not the case.
All you can do now is report the problem to AVerMedia support and see what they say.
[AVerMedia News] Avermedia RECentral HDCP Protect Remove!!!
By Cauptain in forum Capturing and VCRReplies: 235Last Post: 3rd Apr 2026, 23:35 -
[request]Remove HDCP Avermedia EZ recorder 130
By Backstreetboys in forum Capturing and VCRReplies: 12Last Post: 20th Jun 2017, 20:52 -
Video Quality of AVerMedia vs. Hauppauge vs. Other Devices
By Snokomo in forum Capturing and VCRReplies: 10Last Post: 9th Sep 2016, 13:00 -
Avermedia extremecap u3 with ps4 - best bitrate / fps / quality settings
By Gabriel Pelegrino Gama in forum Newbie / General discussionsReplies: 8Last Post: 10th Jun 2016, 06:29 -
Problem with Avermedia
By JustRyuzaka in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2013, 08:34
