  1. I'm very new to using FFMPEG and other streaming devices.
    I've got ffmpeg og ism downloader. If that's info you need.
    Here's an example from the site: http://sumo.tv2.no/programmer/serier/kingdom/sesong-2/kingdom-2-episode-1-968797.html?...howPlayer=true
    I then go to souce code, by clikcing near the webplayer. I did not need a subscription to access the videos. But, now they change their player and I can't get it anymore!
    With or without a subscription. I've tried using sniffer, HDS thingy in firefox, nothing works.
    Back to the example. I go to the source code of that link. Scroll down, so I then get this code and make it a bat file.
    ffmpeg.exe -i "http://tv2-stream-od.online.no/dashvod2/_definst_/amlst:968797_ps101020_pd2721500.smil/manifest.mpd" -c copy -bsf:a aac_adtstoasc "Video.mp4"
    pause
    This used to work before, but not now. Now I get a message saying "Invalid data found when processing data". Sometimes I get the 403 forbidden message.
    I've tried everything.
    But nothing works. They changed their webplayer and ruined everything, again. This is the third time this year.
    Can you see what I need to change?
    I tried URL sniffer, and found this:
    http://tv2-stream-od.online.no/dashv...l/manifest.mpd
    It doesn't work, I get this error: Invalid data found when processing input
    This file however, might be to help. I see some data in there that might be a huge help. But, I don't know what I'm looking for. This file is completley safe. It's for a different video than the example, and you can only access the manifest file with the sniffer with a subscription. I don't have one at the moment, but did when I get this file. It has some data in it and a "chunk" file.. maybe you know what I need? what code I need, how to get these videos?
    I do have Php AdobeHDS too. Tried this in desperation. Never thought it would work:
    php AdobeHDS.php --manifest "http://tv2-stream-od.online.no/dashvod2/_definst_/amlst:1059244_ps18000_pd2314530.smil/manifest.mpd" --delete
    pause
    "No media entry found", as expected.
    Do you know what to do? What command do I need? what info? help! I'm completely lost here.
  2. HDS Link Detector doesn't react at all either. I use it to get the manifest for some sites, and uses it in Php AdobeHDS.
    But it doesn't work on this website. With, or without subscription.
  3. No one? Please I need help
  4. Not a single person?! Really? PM or whatever is ok too. I need some help.
    Do you know of a better place to ask?
