Results 1 to 13 of 13
  1. I just made an mp4 clip (here's the mediainfo)
    General
    Complete name : C:\Users\Bruce\Desktop\test.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 2.03 MiB
    Duration : 2s 112ms
    Overall bit rate : 8 045 Kbps
    Encoded date : UTC 1970-01-01 00:00:00
    Tagged date : UTC 1970-01-01 00:00:00
    Writing application : Lavf53.2.0
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 2s 86ms
    Bit rate : 8 000 Kbps
    Width : 1 904 pixels
    Height : 1 072 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (23976/1000) fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.163
    Stream size : 2.00 MiB (99%)
    Writing library : x264 core 115 r1995 c1e60b9
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=1 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=8000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 2s 112ms
    Bit rate mode : Variable
    Bit rate : 89.0 Kbps
    Maximum bit rate : 320 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Frame rate : 46.875 fps (1024 spf)
    Compression mode : Lossy
    Stream size : 22.9 KiB (1%)
    and I'm getting a black flashing rectangle in the lower right of the video when I play it with Media Player Classic Home Cinema. If I expand the view to full screen, the rectangle moves to the centre. In Options, Playback, Output, I've got DirectShow Video set to Enhanced Video Renderer (custom presenter) Can anyone tell me why I'm getting a black flashing rectangle?
  2. What about other media players?
  3. Originally Posted by jagabo View Post
    It plays absolutely fine in Windows Media Player, and in Firefox's own internal player, somewhat stickily in PotPlayer, and VERY stickily in GOM Player. MPC-HC is my preferred player though so I'd like to see if there's a way to get rid of the black rectangle.
  4. Ok, so we know the problem isn't in the video file. I don't see anything obvious about the file properties that would cause such a problem.
    As a test, have you tried different output devices in MPCHC? Try remuxing to MKV and see if the problem persists.
  5. Originally Posted by jagabo View Post
    You're gonna have to tell me how to do that, I'm afraid.
  6. The same place you saw you were using EVR Custom Presenter.
    I don't know what's happened but suddenly there's no black rectangle. I don't know what caused it, I don't know what made it disappear, I didn't change anything, so I'm a little worried that it indicates something wrong with my computer.
  8. Oh god almighty, now it's back again! But I'm not doing anything! What the hell is wrong?
  9. Now it's gone again. This is driving me up the wall. I'm not doing anything different. What is with this flickering black rectangle?
  10. Have you rebooted?
    Have you rebooted?
    A few times today. I'm noticing though that this black rectangle thing isn't happening with any other videos. Just this one. But you said you could see nothing wrong in the mediainfo to indicate why.
  12. Just because I didn't see anything unusual doesn't mean there isn't something wrong with the video. MediaInfo only shows what the headers indicate. Did you try remuxing? Maybe just a remux or a remux to another container will fix the problem. I'd try remuxing to MKV with MkvToolnix first.
  13. Originally Posted by jagabo View Post
    Yep, tried that. Didn't work. Same problem.
