Hi
Currently I am using a JVC HE-S9911U VCR
via S-Video into a Datavideo TBC-1000
and then via S-Video again into a HDPVR.
The JVC is set as follows:
Video Calibration On
Picture Control Auto
Digital R3 On
Video Stabilizer Off Unless picture still has jitters then On
S-VHS mode On
Audio Monitor HiFi
Super Impose Off
And the HDPVR is set to capture with Video Quality 15.50 Mbps Constant, Capture is at 720 by 480.
Default for everything else such as Brightness, Contrast, Saturation and Hue and Sharpness bumped up to 100
That Capture gets fed into TMPGenc Video Mastering 5.2.6.65 for trimming and encoding to 100% of the disk setting and Authored with TMPGenc Authoring 5.5.3.108
Results look good from newer S-VHS Tapes from 1989 and 1990 however results with regular VHS from 1980 are so-so.
Hence my question, any suggestions, Possible filtering?
Thank You in Advance
TBoneit
	If I'd known I was going to live this long, I'd have taken better care of myself.
	Regular VHS will never look as good as S-VHS, especially with such an old tape. Leave the TBC-1000 out unless you need it. Digital R3 is an edge enhancer and you also have the HDPVR Sharpness turned up, so you may be getting halos that hurt the picture quality. I leave R3 off and use sharpness judiciously, usually at a low setting. What about the TBC/NR on the deck? Sometimes it's better with it on, sometimes better with it off. Finally, a good Panasonic or Sharp VCR will often play troublesome VHS recordings better than the JVC.
	Hi
 I do leave the TBC in the chain. Currently I am capturing one of many old VHS tapes that will most likely never see a DVD version. This one is a 59 minute tape from 1979 and is marked VHS Copyguard on the plastic sleeve it came in. It is just one of many that have a copy protection scheme and I credit the TBC with capturing them trouble free.
 Hech 54, Do You concur with the other suggestions?
 BTW I saw some suggestions by Lord Smurf in the past....
 Thank You both for the feedback
 RogerIf I'd known I was going to live this long, I'd have taken better care of myself.
  Current recommended workflow for analog capture to H.264 'archive'?By Killer3737 in forum Capturing and VCRReplies: 24Last Post: 26th Apr 2015, 11:24
  Please review my home movie VHS capture workflow.By Jaydee in forum Capturing and VCRReplies: 34Last Post: 26th Apr 2014, 17:44
  Suggestions on Setting up a vhs captureBy boko in forum Newbie / General discussionsReplies: 7Last Post: 4th Feb 2014, 16:45
  Suggestions for VHS capture improvementsBy PandMonium in forum RestorationReplies: 16Last Post: 4th Feb 2013, 08:38
  Current Canadian VHS Capture Help?By Line Noise in forum Capturing and VCRReplies: 1Last Post: 26th Nov 2011, 00:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
