I've been using Solveig Splitter to trim x264/mp4 clips and then join them with no reencoding but it lacks titling (even simple on black background). I've resorted to inserting black scenes filmed with the same camera to avoid compatibility issues.
Is there software out there that can do that or just reencode as little as possible or is it a lost cause ? In this case what's the simplest software with reencoding around? Thanks!
VideoReDo TV Suite 5 has a titling feature, although I have never used it. I think transitions are limited to fade-in fade out. It smart-encodes for MPEG-2 and H.264 input.
I don't have TMPGEnc MPEG Smart Renderer 5, but I tried it and remember it has a titling feature, although I don't recall what it is like. It costs a bit less and smart-encodes MPEG-2, H.264 and H.265 input.
Both programs have a free trial. -
A belated thanks for the quick reply. I'll gave the trial versions a try
Any suggestions on a simple editor or is there little middle ground between these utilities and powerhouses like Premiere ?
I thought SolveigMM Video Splitter, VideoReDo and TMPGEnc MPEG Smart Renderer 5 were all simple/basic editors.
If you want a basic NLE (separate timelines for audio and video), I haven't run across any consumer NLE's with the ability to smart render H.264 camera files. The only basic NLE I have which smart renders, MPEG Video Wizard DVD, is only for MPEG-2 editing. Maybe someone else can recommend one for H.264 editing. -
i haven't looked recently but there used to be premiere elements, and sony movie studio for people looking for an editor at a better price point. sony by far is the easier to learn.
Will look at Sony app, thanks.
@usually_quiet - right these three tools are great, but limited when it comes to adding titles, transitions, audio, etc...hence my search for the simplest possible editor, even if it doesn't offer smart rendering. -
I wouldn't say that they are limited. Movie Studio does titles, transitions, audio and more. I suspect elements does also.
Extraordinary claims require extraordinary evidence -Carl Sagan -
So...I finally got around to trying "TMPGEnc MPEG Smart Renderer 5" and it does work rather well (no reencoding, adding titles and transitions)...except that it does not appear to let you add an audio track, which is a problem for silent drone footage! I suppose I could upload to YouTube and then add an audio track there but it seems a bit silly, besides the files on my HD would be silent.
Does anyone see a way around that ? I seem to remember using Yamb to remux mp4 files but also remember that the audio got all jumbled up. Thanks !
What's wrong with Solveig Video Splitter's GIF function?
By Bruce Wayne in forum EditingReplies: 40Last Post: 12th Apr 2016, 00:05 -
Solveig Multimedia unveils Video Splitter for Android to enable smartphone
By DmitryV in forum Latest Video NewsReplies: 2Last Post: 6th Dec 2015, 16:58 -
any free video splitter / joiner that is probably the best?
By kenny1999 in forum Newbie / General discussionsReplies: 12Last Post: 29th Sep 2015, 13:39 -
Best splitter/trimmer/joiner for every format
By ARTO65 in forum EditingReplies: 53Last Post: 5th Dec 2014, 19:02 -
Fast MOV cutter, splitter, joiner that doesn't encode?
By Georgeo57 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Apr 2013, 18:22
