Hi....I haven't had much luck finding someone to convert VHS, so looks like I am going to have to try do this myself.
I managed to source a Canopus ADVC100 due to the possibility there is a 'trick' to bypass macrovision on a couple of VHS's I have - that aren't available on DVD.
Does anyone have any experience of this converter, and therefore offer advice on how best to set this up?
I've only got the device and the power adaptor, from what I gather I need a firewire cable to connect converter to laptop (complication is laptop doesnt have firewire! do converters work?). Depending on the VHS I source I expect I'll use either svideo or component or composite to connect it to the Canopus device.....
Any recommendations on what software to use for capture...assuming it works as expected!?
Thanks in advance for any help.
Closed Thread
mdemetri2, Do not post the same topic on several forums.
Please do not cross post, once is enough.
Continue in: https://forum.videohelp.com/threads/379733-VHS-Capture-Service-UK-Anyone-offering
Moderator redwudz
Canopus ADVC100 vs cheap USB video grabber?
By itm2 in forum Capturing and VCRReplies: 39Last Post: 25th Nov 2014, 12:05 -
Capturing VHS with Canopus ADVC100
By efiste2 in forum Capturing and VCRReplies: 3Last Post: 15th Dec 2013, 03:14 -
Convert analog videos (VHS, VHS-C, Mini-DV) to digital files
By mays316 in forum Video ConversionReplies: 6Last Post: 4th Mar 2013, 07:47 -
EP VHS, through Canopus 110, to PC
By bthomas in forum Capturing and VCRReplies: 17Last Post: 28th Jul 2012, 03:40 -
Converting VHS to digital, VHS tracking problems?
By ReedJohansson in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2012, 09:54
