I am trying to capture video from a bunch of mini vhs tapes that I have and I have run into a problem. The audio on the finished capture is not synced. First I used Ulead Movie Factory for the capture (Came with the USB capture device I'm using) then I tried using VirtualDub. The problem persisted on both. VirtualDub does not report any frame drops either, so I do not know what is going on. Is it maybe my specs? I have a AMD A8-6410 CPU with integrated Radeon R5 Graphics. Its also worth noting that I tried doing this a few years ago on a less powerful laptop with a different capture device and had the same problem. Can anyone tell me how to fix this? I've tried doing research but most of the answers I found I can't really understand (I'm a newbie to this). All help is appreciated![]()
First step: if you have VirtualDub's audio preview feature turned on while capturing, disable it.
Others have suggested AmaRecTV, though I've had bad experiences with it, myself. -
I only ever got VirtualDub to capture in sync once, after following some arcane directions I found on the internet and sacrificing a chicken. It appears to have a blind spot with respect to USB capture devices. Now I use AmaRecTV, which has a quirky Japanglish interface, but it works.
Audio sync drifts while capturing VHS
By tonewheels in forum EditingReplies: 19Last Post: 8th Feb 2016, 16:38 -
Capturing Lossless VHS Tape
By zack28 in forum Newbie / General discussionsReplies: 33Last Post: 24th Feb 2014, 14:43 -
Capturing HDV off of a mini DV tape?
By Oakie88 in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2013, 11:43 -
Mysterious dark brown tint while capturing old VHS tape
By CraigFarr in forum Capturing and VCRReplies: 3Last Post: 30th Apr 2013, 18:12 -
Capturing VHS cassettes in AVI with VirtualDub- audio and video out of sync
By avz10 in forum Capturing and VCRReplies: 4Last Post: 5th Jan 2013, 00:13
