What is cropping? If I want to cut the video from its background is that cropping? How do I zoom in to where only the.the video is left? What is good piece of software to do this? John
http://www.dictionary.com/browse/cropping?Photography. to cut off or mask the unwanted parts of (a print or negative).
In a video context it's often is used to mean removal from the top/bottom/sides, often of black bars or some sort of crap (such as the head-switching noise from the bottom of a VHS tape capture), or removal of picture to restore or change the aspect ratio (as from 'fullscreen' to 'widescreen').
The AviSynth site says, "Cropping refers to the removal of the outer parts of an image to improve framing, changing the framesize (also called image or storage aspect ratio)."
http://avisynth.nl/index.php/Crop
Wikipedia has a big page on the subject:
https://en.wikipedia.org/wiki/Cropping_(image)
This isn't anything you couldn't have easily looked up yourself.
AviSynth, Virtual Dub, just about any NLE, anything that deals with video.What is good piece of software to do this? -
Cropping question
By killerteengohan in forum RestorationReplies: 7Last Post: 23rd Apr 2020, 07:10 -
cropping problem
By lee09 in forum EditingReplies: 4Last Post: 6th Jul 2014, 10:28 -
Cropping AVI 4:3 to 16:9 need software that allows floating cropping area
By tonyclem in forum EditingReplies: 11Last Post: 26th Nov 2012, 06:48 -
how to do exact cropping?
By WuxiIxuw in forum EditingReplies: 15Last Post: 2nd Sep 2012, 12:52 -
HD Cropping questions
By NotSoEasy in forum Video ConversionReplies: 11Last Post: 29th Apr 2012, 17:39
