I don't mean a very small casing for standard USB, but something that will work for the tiny connectors used on phones and Raspberry Pis.
I'm surprised there isn't one readily available, I have Kingston OTG dual ended drives from Walmarts, but for example using it eliminates the power cord as there is only one socket on a typical smartphone .
btw, an Android section might be good here, there are a crazy number of video related apps for HDR, animation, timelapse, editing, restreaming, hyperlapse- too many to count. Most have nearly non-existant instructions but some clever features.
I have seen hubs with a single OTG input (the Micro USB female port) and multiple USB 2.0 type A female ports.
https://www.amazon.com/Inateck-Adapter-Compact-Compatible-Smartphones/dp/B00OCBXIY8/
https://www.amazon.com/Adapter-Powered-Charging-Charger-Connector/dp/B00LTHBCNM/
It is more likely that Baldrick will see your suggestion for an Android software section if you post it in the Feedback forum. -
Will a USB hub meet my needs?
By GLE3 in forum ComputerReplies: 2Last Post: 15th Oct 2014, 12:03 -
USB microphones, a hub and software
By Haopengyou in forum AudioReplies: 8Last Post: 21st Oct 2013, 07:53 -
Tablet micro usb
By uno in forum ComputerReplies: 6Last Post: 26th Jul 2013, 04:59 -
Looking for a wireless USB hub
By dafoe in forum ComputerReplies: 7Last Post: 3rd Nov 2012, 01:06 -
Samsung micro USB-B to USB-A cable
By luigi2000 in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2011, 15:05
