when i open a .vdr file in CCE it crashes. This is after i install the AVI file handler, and restart. I have Vdub open framserving,but opening VDR file causes it to crash. can someone help me out?
if you are frameserving with virtual dub, do you have audio set to "no audio" ???? because this will cause what you describe. just leave the audio in Vdub and in CCE uncheck for audio file and it will only frameserve the video.
i tried frame serving with Cinema craft, i always get this Unknown Error. I think its my hardware thats the problem. I tried installing 3 versions of CCE but it said i needed a computer that supports SSC or 3d Now! or something like that whenever i run the setup. But I got the oldest version of CCE and i was able to install it, but i I get an unknown error messege when I try to encode or frameserve. Can't do diddily
Are you running a PII or a celeron under 500mHZ? that would explain the errors you are getting.
checkin my hardware profile, let me see, i got a :
AuthenticAMD
AMD-k6(tm) 3d proccessor
60.0 mb ram
oh my computer is like 460 mhz or something around there, yea my computer is old and junky
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 10:45 -
Simple DivX: Crashes with Mencoder Error Every Time
By CobraPilot in forum DVD RippingReplies: 5Last Post: 10th Jul 2008, 19:47 -
CCE, MP4 and AviSynth Error
By Maikeru-sama in forum Video ConversionReplies: 28Last Post: 11th Jun 2008, 04:24 -
hp dvd 1040i, hp simple backup, error message:sbwin32.exe has generated err
By 84transam in forum DVD & Blu-ray WritersReplies: 4Last Post: 8th Jan 2008, 13:18 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 04:46
