Hi folks,
The last several AviDemux 2.6.12 Nightlies (r290716 and r300716) when I try to run them while tries to open it gives me the following error ...
"The procedure entry point GetNumaNodeProcessorMaskEx could not be located in the dynamic link library KERNEL32.dll"
My laptop is Windows Vista X64 and pretty old. The Program file I am running is the Portable "avidemux_r300716_win64Qt5.7z".
Q: What is the problem and is there a Fix?
BTW, I run nothing but Portable versions and the older version of AviDemux run just fine ... open up without the above error message.
Thanks,
G!![]()
See this:
https://msdn.microsoft.com/en-us/library/windows/desktop/dd405493(v=vs.85).aspx
At least Windows 7 is required
mpc hc nightly 64bit setting help please-resizing
By rockerman in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2016, 11:19 -
Advice needed for AviDemux 2.6.8 v2 / nightly
By rgb in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2014, 21:15 -
AppHang opening .mov files with AVIDemux 32 bit but not 64 bit.
By redwudz in forum EditingReplies: 9Last Post: 4th Mar 2014, 21:47 -
DVDstyler error opening filters
By Patapin in forum Authoring (DVD)Replies: 3Last Post: 10th Nov 2013, 13:43 -
Avidemux 2.6.1 closes after opening video: How can I fix that?
By johnharlin in forum Newbie / General discussionsReplies: 3Last Post: 30th Jan 2013, 00:38
