newbie here, so not sure if I'm posting this under the right section.
I've saved a DVD onto my PC. It's some old home movie footage that's been professionally transferred onto disk from a VHS tape. I wondered if there was a way to compress the folder size as it's quite large [2.5GB] and I'd like to be able to email it to family.
It's in a folder called 'VIDEO_TS'. The folder contains a few different types of files ... 3 x .BUP 3 x .IFO & 7 x .VOB
I tried compressing the folder into a zip file using windows file explorer. However it made virtually no difference to its overall size.
It should be clear that I am a complete novice at this. I'd appreciate any advice on how I can compress the video folder so I can easily send it via email. Alternatively, could the folder be converted to another format ie mp4??
Thanks.
My guess is, you could compress that into the 700-800 MB range. That is still too much for most e-mail systems. As almost any video would be too much for e-mail. Better find a (temporary) host and just link to your .mp4 file that way.
+1 on uploading to an free online host (e.g. Google Drive, Dropbox). Even if you're able to email a by comparison "smaill" 700-800MB file to someone, it's really bad etiquette to do so. You'd be slowing down and filling up the receipent's inbox.
In addtion, you can convert your files to .mkv using MakeMKV (free) which will retain the quality of the original (if ti's precious enough to share, share the best) and be just as, if not more likely to played by those you're sharing with.
Devices to play VOB files in VIDEO_TS folder like a DVD?
By MoreQsThanAs in forum Newbie / General discussionsReplies: 15Last Post: 15th May 2014, 09:39 -
adding vob file into video_ts folder
By ponnu_2013 in forum Newbie / General discussionsReplies: 7Last Post: 27th Dec 2013, 12:51 -
How to change single VOB file to VIDEO_TS folder
By skyllasibe in forum Newbie / General discussionsReplies: 10Last Post: 9th Jun 2013, 05:02 -
Compress .VOB files using DVDShrink 3.2
By JasonQuinn1992 in forum Video ConversionReplies: 5Last Post: 26th Jun 2012, 01:57 -
Is the VIDEO_TS folder supposed having the .VOB file?
By coody in forum DVD RippingReplies: 6Last Post: 19th Dec 2011, 01:38
