I am trying to remove a credit roll that plays over footage at the end of a TV series. The text is white with a black shadow and every ending credit roll is unique, but played over the same footage. Is there any way to restore just the footage portions and ignore the text?
I laid two credit sequences over each other with the blending mode set to Lighten and it does a fair job of removing the white text, however the shadow is more difficult.
Here is an example:
https://www.dropbox.com/s/eomgfatj4g0rop7/credits-s.mp4?dl=0
and here are 4 different credit rolls:
https://www.dropbox.com/sh/16wkmy10jdes56f/AAAgaaXrp6xHpEErHQtmVA59a?dl=0
I have seen restoration methods that use multiple passes from the same video to restore detail and was wondering if something similar could be applied to this.
	You might be able to get a median filter to work if you have enough sources. But your sources all have different levels, framing, and zoom making it much harder.
 https://forum.videohelp.com/threads/362361-Median()-plugin-for-Avisynth
  Removing Cinavia protection,100% working methodBy stijo Mathew in forum Video ConversionReplies: 31Last Post: 8th Mar 2016, 02:30
  Best method of removing buzz from captured audioBy snafubaby in forum Capturing and VCRReplies: 4Last Post: 31st Jan 2016, 19:46
  My method of removing a logo, need adviceBy -Habanero- in forum EditingReplies: 4Last Post: 22nd Aug 2015, 16:55
  HDV .m2t footage - Best quality conversion to MPEG4- method/toolsBy Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2012, 02:30
  can't scroll through movieBy griggrig in forum Software PlayingReplies: 4Last Post: 18th Oct 2011, 20:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
