  1. hi is it possible to capture the live stream to see through vlc http://www.ntvplus.tv/#!/cast/channel/5006df67d122fa3f0d000000/
    <manifest xmlns="http://ns.adobe.com/f4m/2.0">
    <id>1024</id>
    <baseURL> http://live-1-201.rutube.ru/stream/1024/HDS/SD/Gm1qC1LmhFu96EreU5it-Q/1469941524/S-g:1soc185ndj24i0jjjiy9zhsu/move/four/dirs/upper/</baseURL>
    <dvrInfo beginOffset="0" endOffset="0" />
    <streamType>live</streamType>
    <media href="/1024-288p.f4m" bitrate="700" />
    <media href="/1024-360p.f4m" bitrate="1500" />
    <media href="/1024-576p.f4m" bitrate="2500" />
    </manifest>
    <?xml version="1.0"?>
    <id>1024</id>
    <baseURL>
    http://live-1-201.rutube.ru/stream/1024/HDS/SD/Gm1qC1LmhFu96EreU5it-Q/1469941524/S-g:1...ur/dirs/upper/
    </baseURL>
    <dvrInfo beginOffset="0" endOffset="0"/>
    <media href="/1024-288p.f4m" bitrate="700"/>
    <media href="/1024-360p.f4m" bitrate="1500"/>
    <media href="/1024-576p.f4m" bitrate="2500"/>
    </manifest>
    livepkgr/events/_1024_/1024</
    1024-576p" url="../../../streams/livepkgr/events/_1024_/1024/1024-576p
    ../../../streams/livepkgr/events/_1024_/1024/1024-288p
    http://live-1-101.rutube.ru/stream/1024/HDS/SD/qGJon8NUDBREqNlFK2V4kg/1469925906/S-g:1.../1024-288p.f4m http://live-1-101.rutube.ru/stream/1024/HDS/SD/qGJon8NUDBREqNlFK2V4kg/1469925906/S-g:1.../1024-576p.f4m
    http://live-1-101.rutube.ru/stream/1024/HDS/SD/qGJon8NUDBREqNlFK2V4kg/1469925906/S-g:1.../1024-360p.f4m
  2. Anonymous84347344
    Guest
    Livestreamer:
    livestreamer "hds://live-1-201.rutube.ru/stream/1024/HDS/SD/wNCfNf0f6ST87Uu417d21w/1469966159/S-g:xpnpbjjzkgs5vdlvhrokspr7/move/four/dirs/upper/1024-576p.f4m" best
    [cli][info] Found matching plugin stream for URL hds://live-1-201.rutube.ru/stream/1024/HDS/SD/wNCfNf0f6ST87Uu417d21w/1469966159/S-g:xpnpbjjzkgs5vdlvhrokspr7/move/four/dirs/upper/1024-576p.f4m
    [cli][info] Available streams: 1024 (worst, best)
    [cli][info] Opening stream: 1024 (hds)
    livestreamer "hds://live-1-201.rutube.ru/stream/1024/HDS/SD/wNCfNf0f6ST87Uu417d21w/1469966159/S-g:xpnpbjjzkgs5vdlvhrokspr7/move/four/dirs/upper/1024-576p.f4m" best -o MatchTV.flv
    [download][MatchTV.flv] Written 3.0 MB (5s @ 531.4 KB/s)
  3. thank you very much only broadcasting is a little late than online
