Hi,
I have about 100 mp4 files that need the exact same amount of audio delay applied (-250ms) I also want the end products in mkv, if I transcode them from mp4 to mkv, according to MediaInfo they already have -42ms when so they'd need -292ms in total? Problem is, whenever I run them through MKV merge, even if I put in -250, MediaInfo then says something like -36ms, so it doesn't want to apply negative delays, positive delays work perfectly though.
any ideas?
thanks
mkvmerge may delete samples so the value you see after the conversion in MediaInfo may not be the delay that was actually applied. This only happens with negative delays. You have to decode in e.g. a wave editor and manually measure if the delays add up to your desired value. You may also use the display statistic tags written by mkvmerge as hints. You can read them using mkvinfo. The track duration will be shortened according to the length of the deleted samples.
Example.
Mux sample A without specifying delay in mkvmerge. Mux sample B while setting "delay" to "-250"ms. Source audio delay according to MediaInfo: -42ms.
Sample A:
Delay according to MediaInfo: -42ms.
Audio track duration according to mkv tag written by mkvmerge: 00:03:00.160
Sample B:
Delay according to MediaInfo: -36ms.
Audio track duration according to mkv tag written by mkvmerge: 00:02:59.904
Math:
00:03:00.160 - 00:02:59.904 = 256ms
256 ms + 36ms - 42ms = 250 ms
And -250ms was the delay we set so it adds up exactly.Last edited by sneaker; 30th Jul 2016 at 14:47.
MKVmerge video delay not working
By CyberTootie in forum Video ConversionReplies: 12Last Post: 22nd Apr 2015, 22:44 -
Getting 120 ms delay with mkvmerge
By rated_x75 in forum Video ConversionReplies: 2Last Post: 4th Apr 2015, 17:17 -
How to Prevent MKVMerge adding a delay?
By VideoFanatic in forum Video ConversionReplies: 27Last Post: 28th Sep 2014, 22:21 -
MKVMerge Delay with Blackness
By Elegant in forum EditingReplies: 21Last Post: 10th Jul 2014, 14:03 -
Mkvmerge stretch by and delay
By kenryuakuma in forum EditingReplies: 2Last Post: 30th Aug 2011, 13:11
