Hi
Am using latest version of above prog to convert multiple mpg4 to mpg2 video files. Have used DVD PAL Large, 520*476, 6000 bit rate etc. (default audio).
Every time mpeg created has good quality but no sound. Windows media player on pc won't open files at all. Media player classic-home cinema plays with audio. I use Corel Video Studio to edit etc and when I import megs there is no sound.
Probably something to do with my settings in FF but not sure where I'm going wrong. I have noticed that on conversion some mpegs have a green down arrow while some have a red up arrow. They all have a different % shown. Can someone please explain what this signifies.
Any advice would be much appreciated.
Thanks for your time.
Steve.
Thanks for prompt response. Not at home now so will post video properties later.
Thanks again. -
And provide information on what you are actually trying to accomplish. There is likely a better solution to meet your usage.
Google is your Friend
Factory Format User
By Kishikuma in forum Video ConversionReplies: 1Last Post: 24th Jun 2016, 16:00 -
Problem using Format Factory
By Stef2010 in forum Video ConversionReplies: 9Last Post: 19th Aug 2014, 07:41 -
Always getting subtitles in format Factory
By buckm in forum Video ConversionReplies: 4Last Post: 27th Dec 2012, 09:47 -
has anyone tried FORMAT FACTORY
By hilario in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2012, 15:42 -
Format Factory problem
By Stef2010 in forum Video ConversionReplies: 6Last Post: 29th May 2012, 15:31
