  1. Hi bro!!
    I am studying: H.264 standard,I use JM reference software to encoded yuv file and I have a question.
    what difference between yuv file (a)before(.yuv) and(b) after(.264) encoded and (c)decoded(.yuv).
    (a),(b),(C) is 112kb. is not (a) > (b)?
  2. Source yuv file is used as reference for reference decoded yuv (i mean there is some abstract reference decoder which is used to decode compressed video and outcome of this are decoded yuv) - then any differences from reference can be counted and some measurements performed - for example PSNR use this method. I assume this is your problem.
