Old 80's TV show - music video re-aired and captured/recorded in 16x9 with black bars on the sides....need to get back to 720 x 576:
I need a good program to get to something lossless or something like HuffyUV so I can start cropping and resizing.Format : MPEG-TS
File size : 102 MiB
Duration : 4mn 53s
Overall bit rate : 2 923 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=2, N=50
Codec ID : 27
Duration : 4mn 53s
Bit rate mode : Constant
Nominal bit rate : 2 700 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.117
Audio
Menu ID : 1 (0x1)
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : No
Muxing mode : ADTS
Codec ID : 15
Duration : 4mn 53s
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Video delay : -39ms
I did another exactly like this(same artist, same show, same source) with AviDemux and VirtualDub and it
turned out perfect....but this one is giving me problems.
I'm replacing the audio anyway so two separate "streams" is no big deal.
Results 1 to 10 of 10
I do not see why you can not use avidemux to do this.
First get back to 4:3 (forget about 720*576 for the moment) by cropping 160 pixels left and 160 pixels right to leave 960**720.
The only logic I see for 720*576 is for dvd so why not simply export that cropped video from avidemux >> video & audio copy and load the clip in to avstodvd. If you do not want to go straight to dvd then just export from there as mpeg2 4:3. -
The problem with this file is that about 3/4 of the way through the song, something happens that throws the sync off, and it's in a perfect place, and the sync difference in so small.... where I can simply add a few duplicate frames or cut a few frames(haven't figured out which way the sync is going yet) to fix the problem.
I was hoping that the sync problem was caused by a bad initial decompression by AviDemux, so I'm looking/hoping for a slower, more accurate decompression(if that is even possible).
OR....if someone knows of a way to get VirtualDub to allow me to add or take away a few frames without it effecting the CD audio that I am replacing the original audio with.
I do certain things very well and very often in AviDemux and VirtualDub....but I've never been able to add or remove frames without VDub trying to change the audio along with the video changes I have made.
For instance, when I need to remove a few seconds from the beginning of a video, I cannot add the new audio because the audio still starts at the beginning of the clip, NOT where I made my cut.....leaving me with 3 or 4 versions in my working folder (original, cut1, cut2). I don't mind doing that but....while adding dupes or cutting some frames I obviously need to see and hear and verify that my changes are correct....I need to see the lip sync after my changes. -
Once again, AviSynth to the rescue. Using the Loop command, or Trim, or DeleteFrame, you can adjust the video framecount however you like.
We all know of your dislike for AviSynth, but some things it simply does better and more easily than using other methods. You can add the audio into the script and check the synch after doing the adding and/or removing of frames. Or you can encode the video and play it with the audio afterwards, make any needed adjustments and then test it out again. I do this sort of thing all the time. -
Yes but I may need to duplicate frame number 5230 several times....or remove a few somewhere around #5230. Adjusting the entire length of the clip is not going to help me.
I record quite a bit of broadcast news along with other shows from over the air, which I encode and store for later. So naturally sometimes the signal is not the greatest and has errors. To deal with this I like to decode with DSS2. It just seems to deal with errors in the stream much better than other source filters by maintaining sync with the audio. And I just have to extract the audio from the source and don't sync it later on when muxing with the encoded video. While it is frame accurate, it only works well if you start from the first frame of your source. If you trim() off the first 200 frames for example, then it tends to repeat the nearest I frame a couple of times until sync is regained.
I cut my sources with Videoredo before it's handled by DSS2, so this may differ from you. And not sure if and how much this affects sync in my workflow.
http://avisynth.nl/index.php/External_filters#Source_Filters
Example
Code:LoadPlugin("C:\Program Files (x86)\Haali\MatroskaSplitter\avss.dll") dss2("P:\Example.ts", fps=29.970, pixel_type="yv12").AssumeFPS(30000,1001) -
That's exactly what what he told you how to do:
or:Code:Loop(5, 5230, 5230) # add 4 duplicates of frame 5230
And of course you can do the same thing in VirtualDub with cuts, copies, and pastes.Code:DeleteFrame(5320, 5321) # remove frames 5320 and 5321
In both cases you can just mux the audio with the video later.Last edited by jagabo; 30th Jul 2016 at 06:55.
Hold the phone here. AviDemux (after adding my new CD audio into Avidemux) allowed me to delete 13 frames(from the middle) and the audio remained untouched. Perfect for this scenario.
BUT....other times I added a clip, took a bit off of either the beginning or the end(or both), added my CD audio
and the audio started as if nothing was cut. WTF?
Lossless m2ts merge?
By Fabulist in forum Newbie / General discussionsReplies: 20Last Post: 6th Apr 2019, 03:51 -
Premiere export to lossless is not lossless
By Dogway in forum EditingReplies: 66Last Post: 30th Dec 2014, 13:48 -
LOSSLESS Editing
By steveeyes in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2013, 13:26 -
lossless codec
By poluhale2 in forum Newbie / General discussionsReplies: 1Last Post: 7th Sep 2012, 16:48 -
crop video lossless.
By namenone in forum Newbie / General discussionsReplies: 2Last Post: 16th Feb 2012, 18:55
