    Jul 2016
    Watford England
    Using VHS to DVD 5.0 ilast used this about 3yrs ago,i imported and burned loads of VHS tapes,i now want to import some tapes,but I want to save them to a folder on my PC.how do I get them into a folder instead of burning them to disc,these are lots of short videos so I need them onto my pc so I can sort them out then burn to disc.Than You Longlegs
  2. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    It looks interesting but I have never used this product. Iit looks like you would just use the capture mode in advanced method?
    http://www.honestech.com/main/vhs-to-dvd-50-hd.asp
    Jul 2016
    Watford England
    Budman 1 thank you,i have checked out the advanced mode and you can import to folder from there,its that long since I have used the software I had forgotten how to use it.Thanks Again.longlegs
