I rotate a few Shuttle XPC cube desktop computers -- a few models. One of them was working fine last night, but this morning it would Stop | Start | Stop | Start right away during bootup attempts. Haven't run into that much, if at all. In my experience, the proprietary PSUs for these things just burn up one day, which you can obviously smell, and then it's dead, time for a new PSU: no intermediary failures like this. I looked around online, found some mention of cleaning out dust (that's not it here), flakey Power-ON button (doubtful), overheating CPU (doubtful), bad BIOS battery, and so forth. There were even some of those very common replies to similar issues saying "Dude, you've got a virus. Time for Combofix," etc. Bullshit ! If the HDD is temporarily disconnected, and you can't even reach the BIOS Settings screen, it ain't no virus ! We're talking pure, basic hardware issue here.
Google may be our friend, but it does dredge up a lot of very improbable advice.
I removed the 2032 button battery, which tested weak. Replaced it with a fresh one. No more Stop | Start on boot attempts, so it does not appear to have been the PSU, much as I surmised. But now there is no video coming up. Swapped in a brand new video card, but still no video. Can't be cables, connectors, or anything like that, as they remain a constant, and other computers here still come up normally, going in to the same monitor. So I guess that probably leaves the video card slot, of which there is only one PCIe on this computer, or some other general failure with the motherboard ? Unless I'm missing something here . . . ? I may even have a spare MB for this computer, but I was not really feeling up for a complete rebuild.
Results 1 to 17 of 17
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
When that happened to me, it was because the video card became loose. A good show fixed it and I doubled checked for any more loose connections.
(I am always suspicious of those damn power supplies.) -
I'd like to be able to check that, but without being able to see any display for the BIOS settings screens, there's no way to know. I don't believe this model had integrated video, anyway. Haven't had one that did for a long time.
In the past, I've seen a toasted BIOS chip, or a MB that developed some fatal issue, on some Shuttle model. Had to rebuild one from scratch with a replacement MB. But I don't think I've ever seen the cpu go bad, or a video card slot go bad; can't recall whether I've ever had a video card go bad.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
what does it do when the power is turned on? fans turn on, hard drive spin up, any beeps?
HDD spun up (when it was connected); fans were spinning (have to check the one that is on the old video card . . . but the replacement video card I connected briefly was a fanless one). There are at least 3 fans, so I should check all of them. Hardly enough time for anything to get hot, though. No beeps.
If I'm really being thorough, I guess I have to put the first video card into another computer, to see what it does. Maybe ditto for the RAM sticks. But I doubt that's it.
Shouldn't you be able to get into the BIOS settings screens, even if a cpu is non-functional ?Last edited by Seeker47; 30th Jul 2016 at 16:34.
No. The BIOS is software, read and executed by the CPU, that performs initial test and setup functions. If the CPU is dead, or if there is no DRAM, or if there is some other very serious problem preventing the CPU from running, you will not be able to get to the BIOS screen.
No BIOS beeps is a bad sign. If POST doesn't happen, nothing else will, including video. I would pull the BIOS battery to reset BIOS and try again.
If nothing then, substitute the power supply. From there, disconnect all drives except boot and all cards except video and RAM.
If still no go, no BIOS beeps, suspect the MB or CPU.
Removing the CMOS battery for about 30 seconds will reset the BIOS to factory default. The PC will run without a battery, but the clock won't keep proper time.
There is also a jumper to do the same thing, but temporarily removing the batter is usually easier. -
Wouldn't hurt to fire it up no battery, then again with.
Disconnect data and power from all drives, remove data cable from mobo. Disconnect all fans but CPU. Test.
Next, remove video card, test, remove all RAM, test, no beep here is real bad but need to check mobo specific beep codes.
Swap RAM with known good unit, test, same with power supply, test.
If all dead at this point, try briefly with no CPU fan, then you're at a decision point. New board, which is most likely, or new chip, unlikely but faster, or both? -
Were you talking to me ? I found your advice useful, and had begun to follow it. But, this happens to be on a spare rig that is primarily for testing purposes -- not a production machine. My free time has been quite limited lately. I will pursue this further and report back, as soon as time permits. I can't devote a lot of time to running this down however, if I'm not obtaining much in the way of informative results -- in view of much more pressing concerns at work.
Had a similar problem on my desktop,replaced the PSU and now works normally.Any problem before POST is almost always a power one,lead,plug,switch or wall point.
Thanks, joeandmarg0. In the past, when I've noticed the PSU go on one of these, it visibly sparked or smoked (burnt smell afterwards), or was found clearly dead. It did not occur to me that power could continue being supplied to some things (the MB lights up), but not to others. Replacing a PSU like these -- with the extremely tight spacing of the Shuttle's small and close-together components, is not something I recall being a quick, casual job.
@Nelson37, sorry you took it that way; I could have gone into more detail, but I never misled you: If this was a production machine with critical stuff on it, this would have been a completely different conversation. But as I said, it isn't: it's a test rig, and so does not nearly command the same priority. I'm commuting between three locations, looking after users and a bunch of computers, though when it comes to hardware I'm definitely not an IT guy, even if somewhat forced into subbing for one. (We used to have one, but he became gravely ill, and won't be returning.) This has mostly worked out, so far. But I'll get back to the less essential tasks when I can.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
Troubleshooting Video Recovery - Chopped Filesize
By blaine0002 in forum Newbie / General discussionsReplies: 7Last Post: 26th Sep 2014, 17:59 -
ADVC 300 Troubleshooting
By sunsetandgower in forum Capturing and VCRReplies: 2Last Post: 2nd Mar 2014, 14:38 -
JVC HR-S7600U troubleshooting. Need help to fix.
By ybarra in forum Capturing and VCRReplies: 13Last Post: 16th Aug 2013, 17:49 -
Panasonic DMR-HS2 Troubleshooting
By Patrick Walsh in forum DVD & Blu-ray RecordersReplies: 1Last Post: 1st May 2013, 20:15 -
Troubleshooting a corrupted .wmv file
By JustSteve in forum EditingReplies: 2Last Post: 30th Jan 2012, 17:08
![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
though not yet assigned to that task]
Shuttle SH67H3 (i7)
w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
services for an office, with other computers
there . . . ]
Various older model Lenovo laptops, like T-40
series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
& various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
....I meant "shove" as in shove the card into the slot.
