Hi
in media player classic - how to load the video to ram (cache)?
thanks
Results 1 to 14 of 14
The player doesn't load the whole video, it streams it off of the drive as needed to maintain playback.
And no, you can't load anything into video RAM.
The real question is what exactly are you trying to do and why? Reading data from media isn't often a source of trouble for media playback.Google is your Friend -
You can use simple script to copy movie to RAM disk and later start MPC with file located in RAM disk
Yes, on Linux you can do it, not sure about Windows but i assume yes with proper software.
https://wiki.archlinux.org/index.php/Swap_on_video_ram -
True, but not an automatic "through the media player" solution.
And the question remains, why?
Any scripting or special software is going to simply copy the data from storage (presumably HDD) to the RAM file. But why? Any HDD can read data more than fast enough for video playback.Google is your Friend -
but ram is even faster
& it will not bother the hdd for an hour of film
just 5-10 sec to load to ram & thats it
in vlc you could set it in the preference - how much to load to ram
so i just wanted to know how to do it in media player -
Fair enough. I still don't see that it matters.
As mentioned, HDD is (usually, not counting LL/uncompressed) at least "fast enough". That means it can often be faster than necessary. So, barring editing or multistream or 4k or LL/uncompressed needs, there is no reason for it to need to be even faster than that. The storage only needs to load the frame in time for the frame to be presented at its stated framerate, to avoid dropped frames/jitter/motion aliasing.
Scott -
Anything faster is wasted. But, do what you want...
windowed borderless like vlc player for media player classic?
By Crea in forum Software PlayingReplies: 4Last Post: 21st Aug 2015, 15:11 -
Video stretching in Media Player Classic problem
By AnimeFreak1993 in forum Software PlayingReplies: 5Last Post: 7th Jul 2015, 05:44 -
Media Player Classic Video Enlargement?
By tomkat2010 in forum Software PlayingReplies: 2Last Post: 16th May 2015, 16:56 -
Playing forced subtitles - Windows Media Player/Media Player Classic
By pizzaboyUK in forum SubtitleReplies: 3Last Post: 18th Mar 2015, 02:57 -
Media Player Classic Some Video Look Foggy
By DJboutit in forum Newbie / General discussionsReplies: 3Last Post: 28th Nov 2012, 22:38
