Results 1 to 13 of 13
    Jul 2016
    Wondered if someone could throw some light on this one for me please?
    Got some MKV files that I'm trying to convert to MP4 but when I converted them there was no audio. Looked online quite a bit to try figure it out. Tried demuxing to get an audio file that I can remux with the mkv but most apps I tried don't even give me an audio file.
    I'm on a Mac btw.
    The media info is below.
    General / Container Stream #1
    Total Video Streams for this File.................1
    Total Audio Streams for this File.................1
    Video Codecs Used.................................V_MPEGH/ISO/HEVC
    Audio Codecs Used.................................A_OPUS
    File Format.......................................Matro ska
    Play Time.........................................22mn 11s
    Total File Size...................................142 MiB
    Total Stream BitRate..............................896 Kbps
    Encoded with......................................mkvmerge v8.7.0 ('All of the above') 32bit
    Encoding Library..................................libebml v1.3.3 + libmatroska v1.4.4
    Video Stream #1
    Codec (Human Name)................................V_MPEGH/ISO/HEVC
    Codec (FourCC)....................................V_MPEG H/ISO/HEVC
    Frame Width.......................................1 280 pixels
    Frame Height......................................720 pixels
    Frame Rate........................................23.976 fps
    Total Frames......................................31913
    Display Aspect Ratio..............................16:9
    Video Stream Length...............................22mn 11s 39ms
    Audio Stream #1
    Codec............................................. A_OPUS
    Codec (FourCC)....................................A_OPUS
    Audio Stream Length...............................22mn 11s 25ms
    Number of Audio Channels..........................2
    Sampling Rate.....................................48.0 KHz
    Audio Stream Language.............................Abkhazian
    Aug 2010
    San Francisco, California
    Don't think you're allowed to put Opus audio in an MP4 container. FFmpeg will do the job:
    ffmpeg -i myinput.mkv -c:v copy -c:a aac -b:a 160k(or whatever audio bitrate you want) myoutput.mp4
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Assuming the original files play fine, the problem would likely be with whatever tool you used to perform the conversion.
    Give VidCoder a try.
    Google is your Friend
  4. Or something that can use "Copy" for the video like Xmedia Recode.
    Jul 2016
    Thanks guys - I'm on a mac, are there equivalents to the apps you mentioned?
    Tried ffmpeg through terminal and I get an 'unknown format' error:
    [matroska @ 0x5597b8]Matroska demuxer version 1 too old for file version 2
    /Users/mainuser/Desktop/movie.mkv: Unknown format
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I've never used a mac, much less tried to find software for one.
    Mac's are great if you use the professional tools, but once you start trying to find free or cheap tools, 99% of the users, and thus the tools are Windows based.
    As for the error, it would appear you are using an old version of ffmpeg.
    Good luck.
    Jul 2016
    Vix x
  8. I'm a Super Moderator johns0's Avatar
    canada
    Thread moved to the mac forum where you can get more help.
    Aug 2010
    Download the latest FFmpeg from
    https://ffmpeg.org/download.html#build-mac
    Jul 2016
    Tried the latest ffmpeg build and it's still giving me the unknown format error. I tried Handbrake previously but in the audio tab it's showing no audio channel - it plays fine in VLC.
    Very frustrating!
    Vix x
  11. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Are you sure you called on the new ffmpeg 3.1.1 binary correctly? It sounds a bit presumptuous, I know, but (a) that old demuxer error is really old and should have been resolved several versions ago and (b) ffmpeg 3.1.1 works with the HEVC/OPUS MKV version 2 that I could find. I tried the OSX Experts and Tessus (Evermeet) pre-compiled versions of ffmpeg 3.1.1 in Terminal and a conversion with the iFFmpeg GUI (backed by the OSX Experts binary).
    Jul 2016
    Case the OSXperts with the iFFMPEG GUI seems to have worked! Really appreciate all your help guys
    Vix x
