Hi, i just downloaded two rips of the same movie, one is 29GB and the other is 16GB. they are both mkv and 1080p. I took a screenshot from the same frame of both rips and compared it, but they are the same quality, even the audio sounds the same. when pressing on codec information on vlc I see that both video and audio have the same specs as expected. the only difference between the two rips are the size and the amount of softsubs, I know that subs dont take much hdd space so that cant be it. So my question is, why is the one bigger than the other?
Closed Thread
Subjective comparisons don't hold the answer. Post the MediaInfo analyses of the files.
[MKV] problem with AR/sizes
By tozzy in forum Video ConversionReplies: 6Last Post: 30th Jan 2016, 13:08 -
Blu-Ray player that reads MKV files with options for subtitles sizes/fonts?
By JukeboxAMI in forum DVD & Blu-ray PlayersReplies: 4Last Post: 31st Jan 2015, 15:02 -
Quality vrs Size - MKV - HandBrake quality option best solution?
By StumpedTechy in forum Video ConversionReplies: 12Last Post: 28th Sep 2014, 17:35 -
Variance in MKV file sizes
By MikeC58 in forum Blu-ray RippingReplies: 3Last Post: 9th May 2014, 09:59 -
what to convert trp vidio too good quality but smaller file sizes?
By matey in forum Video ConversionReplies: 1Last Post: 2nd Jul 2013, 09:39
