I picked one of these up to record some video footage onto my PC via VirtualDub. However, nothing is showing up under Capture Devices in the capture settings in VirtualDub. I get video and audio via EzGrabber but I have no desire to capture using that software or lossy codecs. Can anyone suggest why the Diamond is not showing up in VirtualDub please?
Thank you for your time and efforts.
Results 1 to 9 of 9
What OS? Someone recently had the same problem on Win10 (no solution).
https://forum.videohelp.com/threads/379449-Diamond-VC500CXT-only-partially-functional -
I'm now using AmaRecTV for uncompressed capture. Don't know if it will solve your problem, but for me it captures without the audio sync headaches of VirtualDub.
OK. No harm in my trying, I guess! I will post back later and let you know. Thanks for the suggestion, and have a great night.
video quality issues - Diamond vc500
By brwalter in forum Capturing and VCRReplies: 9Last Post: 29th Jan 2016, 11:39 -
video quality issues - on a Diamond vc500
By brwalter in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2016, 15:20 -
Diamond VC500 One Touch Capture Device problems
By ZEROthefirst in forum Capturing and VCRReplies: 18Last Post: 26th May 2015, 15:35 -
Diamond VC500 - install problems with Windows 7
By ry1633 in forum Capturing and VCRReplies: 12Last Post: 17th Feb 2015, 17:08 -
Diamond Video Capture VC500 Problem + Settings
By Firelance in forum Capturing and VCRReplies: 1Last Post: 18th Feb 2012, 05:04
