Hello, I'm trying to encode using a very specific version of x264, and compare encodes with other versions.
x264 core 80 r1376M 3feaec2
I found the source but not a compiled version, and I'm not able to compile it.
I'm trying to recreate an old encode as close as possible but newer versions add more options, the purpose of this is to get some compatibility with an old device.
With the current test encode I'm losing some speed with 29.97 fps, I want to know if using this old version may make it easier to decode.
If someone can explain to me that older versions aren't really easier to decode, then that would save me some time.
Basically the old encode plays perfectly but my recreation has some slowdown, the clear difference I see is that my encode has some extra settings and is a recent x264.
older versions aren't really easier to decode. If you have an old encode that appears to play more smoothly, the difference is likely in the setting used
You can make an encoder easier to decode by adding --tune fastdecode . You can also use VBV settings and bitrate ranges appropriate for your target device -
OK
Source video:
x264 - core 80 r1376M 3feaec2 - H.264/MPEG-4 AVC codec - Copyleft 2003-2009 - http://www.videolan.org/x264.html - options: cabac=0 ref=3 deblock=1:0:0 analyse=0x1:0x111 me=umh subme=6 psy=1 psy_rd=1.0:0.0 mixed_ref=1 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=0 chroma_qp_offset=-2 threads=3 sliced_threads=0 nr=0 decimate=1 mbaff=0 constrained_intra=0 bframes=0 wpredp=0 keyint=48 keyint_min=25 scenecut=0 rc_lookahead=48 rc=2pass mbtree=1 bitrate=1350 ratetol=1.0 qcomp=0.50 qpmin=8 qpmax=51 qpstep=4 cplxblur=20.0 qblur=0.5 vbv_maxrate=2025 vbv_bufsize=2700 ip_ratio=1.40 aq=1:1.00
x264 - core 142 r2479 dd79a61 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=0 ref=3 deblock=1:0:0 analyse=0x1:0x111 me=umh subme=6 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=0 chroma_qp_offset=-4 threads=3 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=0 weightp=0 keyint=48 keyint_min=25 scenecut=0 intra_refresh=0 rc_lookahead=48 rc=2pass mbtree=1 bitrate=1350 ratetol=1.0 qcomp=0.50 qpmin=8 qpmax=51 qpstep=4 cplxblur=20.0 qblur=0.5 vbv_maxrate=2025 vbv_bufsize=2700 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00Last edited by xAlienxx; 26th Jul 2016 at 19:05.
UncropMKV... (alternatives? Way to update it's version of x264?)
By Lathe in forum Video ConversionReplies: 10Last Post: 11th Dec 2013, 13:05 -
ProjectX compiled EXE version
By mr.duck in forum DVB / IPTVReplies: 21Last Post: 7th Aug 2013, 12:40 -
show x264 command line output when using megui as x264 gui
By codemaster in forum Video ConversionReplies: 4Last Post: 12th Mar 2013, 10:35 -
Xvid vs x264 -- Bit Rate: 1900 kbps -- Same quality but smaller x264 file?
By kingaddi in forum DVD RippingReplies: 17Last Post: 2nd Sep 2012, 11:45 -
Where may I get the last version of the x264 - 64 bits version codec?
By daniel827 in forum EditingReplies: 5Last Post: 27th Dec 2011, 18:55
