Hi,
I've been using BDRebuilder for some time now, to shrink my BD-50 blu-ray disks in order to make a copy onto BD-25 disks (because BD-50 disks are too expensive). Problem is that BDRebuilder, although great in quality, is making some of my copies to skip frames. It displays the same frame for let's say half a second than skips the rest, moves to the following and so on. Those disks are unplayable. I tried on my BD computer writter, on my standalone player and the result is the same. Some disks work flawlessly, which is weird, becaue I am using the same settings to every disk. I'm guessing that some encoders or something else have problems with some discs. For instance, discs 1 and 2 from The Big Bang Theory box-set work perfect, but disc 3 not, it skips frames. What to do please ? Thanks.
It sounds like it may be a bad rip, either a dirty/scratched disc, a problem with your decryptor program, or even a failing drive. If it was a BD-RB problem, most likely you would have trouble with every disc.
Do you get the skipping when you play the files on the hard drive before you burn to BD25? If the files play without skipping it would mean a burning problem or bad blank discs. -
No, disc is fine. Even the ripped ISO play fine on PC, from hard drive. It's definitely a BDRebuilder (or an encoder something, related to it) problem. So, the disc play fine on optical unit, the 1:1 rip (an ISO copy of the disc on my hard drive) play fine on computer, but when I try to shrink the copy with BDRebuilder, that's where problems occour.
The burner is fine. Even the shrinked copy skips when played from hard drive. It's 100% something related to BDRebuilder, but I don't know where. -
Completely uninstall BD-RB and all support programs and then reinstall. Sometimes the settings of the decoders can be changed and reinstalling resets them to their default settings.
Try different decoders in the BD-RB settings. You can select LAV Directshow Filters, ffdshow, or the built in LAV in x264. There is also an Intel and Nvidia (needs license) decoder option. If you have a problem with one, try another that will work best on your system.
Bluray drive wont load particular disks while other disks play fine
By archie134 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2016, 05:50 -
Skipping Frames Backward in VD or other editors
By danswano in forum Authoring (DVD)Replies: 7Last Post: 12th Aug 2013, 10:45 -
KMplayer Skipping or Speeding-Up Frames
By Wanderlustus in forum Software PlayingReplies: 3Last Post: 26th Jan 2013, 22:38 -
How could I do a very fast conversion from MPG skipping video frames?
By falco2000 in forum Video ConversionReplies: 21Last Post: 23rd Sep 2012, 11:44 -
AVI Problem - Skipping Frames
By gonwk in forum Newbie / General discussionsReplies: 4Last Post: 4th Dec 2011, 13:43
