Hi
Could someone help me out? I want to convert a mov clip to an mpeg clip
i do that conversion wit TMPGenc , but when i've done the conversion , there's no sound, how do i extract the audio ( wav ) from a mov clip , wich program? and where can i get it ?
please help me out thnx !
One option (the costly one) is to upgrade to Quicktime Pro. It will cost you $29.99. With Pro, you will be able to rip the sound into wav form. But, the upgrade is only for Quicktime 5, so when 6 comes out, you have to pay to upgrade again.
Second option is to use Rad Video Tools (freeware) and convert to avi, then with TMPGEnc, convert to Mpg. You can find out how to do that on this site under this link: http://www.vcdhelp.com/mov2avi.htm
Your third option is to actually record the audio while it plays from Quicktime with your built in Sound Recorder (only on Windows). This gets quite tricky because you have to perfectly line up the audio and video when you do convert to MPG.
Those are all the options that I can think of right off the bat.
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 11:07 -
How can I extract mp3 audio from .mov container without re-encoding?
By Danteism in forum MacReplies: 16Last Post: 3rd Jul 2010, 05:11 -
cannot extract wav from AVI
By ecc in forum AudioReplies: 3Last Post: 22nd Jul 2008, 19:21 -
how do I extract audio from mov mpeg-4 video in Ubuntu Gutsy?
By hurtstotalktoyou in forum LinuxReplies: 2Last Post: 25th Dec 2007, 04:50 -
Extract audio to WAV using VirtualDubMod
By jimmalenko in forum User guidesReplies: 15Last Post: 14th Nov 2007, 03:42
