Hello,
I was wondering if it's possible to fix video that has odd 'bob' to it, like it was improperly deinterlaced (I think so) without access to original recording.
The video that shows what I am talking about: https://www.youtube.com/watch?v=dpU9R4p5AdQ
Something like this in AviSynth helps a lot:
The original video on the left, fixed on the right...Code:LWLibavVideoSource("Bio Channel_ Leslie Cheung (Full).mp4") v1 = SelectRangeEvery(3,1,0).QTGMC(InputType=1, preset="fast") v2 = SelectRangeEvery(3,1,1).QTGMC(InputType=1, preset="fast") v3 = SelectRangeEvery(3,1,2).QTGMC(InputType=1, preset="fast") Interleave(v1,v2,v3) QTGMC(InputType=1, preset="fast") -
It's an odd deinterlace. It looks like it was bobbed but instead of the usual 60 fps video with the frame bouncing at each frame, it's 30 fps with a pattern three frames up, three frames down... If it was the usual type of bob you could use a single QTGMC(). But since it has the three frame pattern it required splitting it into three video, fixing each of the three videos with QTGMC(), re-interleaving them, then a final fix with QTGMC().
Which is better: 60i deinterlaced or 30p?
By SameSelf in forum Video ConversionReplies: 8Last Post: 30th Jun 2016, 12:31 -
VHS subtitles incorrectly deinterlaced
By Pseudopode in forum RestorationReplies: 16Last Post: 31st Aug 2015, 14:50 -
Wrongfully deinterlaced video
By pub in forum Video ConversionReplies: 17Last Post: 24th Jun 2015, 17:41 -
Need a simple tool to sync up badly out of sync audio and video
By CompVid in forum EditingReplies: 16Last Post: 26th May 2013, 06:55 -
fix artifacts in video that was not deinterlaced
By codemaster in forum Video ConversionReplies: 3Last Post: 23rd Mar 2013, 22:27
