Hi friends,
i use blue cloner diamond to copy my original bluray discs to BD-R blank discs but i found problem when i tried to play the copy in the LG bluray, the film working normal till around 50% or more ( end of the layer 1 ) then the image stopped.
I tried DVDFab but it stopped in creating the ISO file at 52% also and i don't know why.
Could anybody can help?
Regards
Results 1 to 15 of 15
Hi friend,
I use the free version of Dvdfab but registered version of Blue cloner diamond.
The blank discs is verbatim.
I didn't update the drivers but i tried 2 different laptops with the same result.
N.B.
The Blue cloner diamond complete the ISO file and burned on the blank but working till 50% and freezing the picture but Dvdfab didn't complete the ISO file so i couldn't burn it.
Thanks for your help... -
This sounds like burner failure
Simply not getting s good burn on the second layer, or there is a problem with the lawyer break info
Will the burner play the disc on your PC -
I use open smartburner and the freeze problem happened with all discs except one only.
I tried today with different PC and another writer but with Blue cloner diamond with the same result.
I believe that the problem is burn on the second layer but why except one disc which i tried 2 times and completed successfully.
I couldn't play discs at all on the PC even the one copied successfully.
And if it's BD-R blank problem why one disc only working fine!!
Thanks for your support. -
blue cloner diamond is software, it runs on the PC, you have external bluray drive or an internal bluray drive to use the software
now why can't that drive be used with media software do play a BR disc ?
please explain , this does not make any sense
you have NO software that will play the any BR disc ?
if it wont work on a different PC ? the problem is with the disc media OR with the blue cloner software -
Try: https://forum.redfox.bz/
CloneBD, but it will cost you. One advantage is Cinaia removal, if needed. -
I have LG stand alone blu ray player and Samsung external blu ray writer.
After burning the BD-R disc it works in the LG fine till about 50% and the image freezing and when i try to put the disc in Samsung to use powerdvd software to play the movie on the laptop the computer didn't play the disc.
It could be the problem with the Blue cloner but there is one disc copied fine and i tried Dvdfab but creating ISO file stopped at 50% or 52% and didn't continue at all.
I tried all process on other PC but had the same problem.
It seems the problem when switching from layer 1 to layer 2 but what's the reason i don't know, and if it's the disc media why the Dvdfab stopped at the same point but in creating the image? -
why try a disc of a different brand, just get a small pkg
and also try reading a DIFFERENT movie disc
maybe that one has a problem
is a recent new release, you might need to update both softwares dfab and blue cloner -
Dear Friend,
I will try different brand although there is one movie copied successfully with the same disc brand twice.
I use the latest version even dvdfab or blue cloner.
But which i try to understand that the Dvdfab stuck in the middle of creating the image which means there is something in the original disc although i tried around 7 different movies!!
I wonder if there is something on the second layer of the disc like kind of protection prevent the copying? -
Dear Friend,
I used the latest version DVDFAB but which i tried was the blue cloner diamond last version with different PC and different blu-ray drives with the same result.
The only thing i used and haven't another solution was the media which is the Verbatim Discs but after the DVDFAB stopped at the middle of creating the image i supposed it is not the disc.
I am sure that the problem in the second layer of the original discs although i tried many different movies but i don't know what's it exactly !!! -
Dear Friends,
My original Blu-Ray package included 2 discs ( 2D - 3D ), the problem seems with the 3D because the 2D one copied normally.
Any idea?
Anybody have original install discs for Canopus DVStorm-RT card?
By AVCHDfreak in forum Capturing and VCRReplies: 2Last Post: 13th Jun 2015, 20:31 -
How to backup a BLURAY 50GB to BLURAY 25GB
By callidus in forum DVD RippingReplies: 14Last Post: 12th Mar 2014, 17:08 -
Bluray players not compatible with MutliAVCHD Bluray discs
By VideoFanatic in forum Authoring (Blu-ray)Replies: 3Last Post: 29th Aug 2013, 15:59 -
Can Bluray players play TS h264 (ac3) Data Discs?
By VideoFanatic in forum Authoring (Blu-ray)Replies: 16Last Post: 25th Dec 2012, 12:49 -
Bluray backup with Imgburn
By tarzan54 in forum Blu-ray RippingReplies: 16Last Post: 17th Jan 2012, 12:11
