I have a clip I recorded some years ago with some low light setting in my camera which caused the clip to (dont know the correct english word) but to pulse, to be jerky in playback.
Is there some plugin in premiere that can help me to smooth the playback?
Results 1 to 10 of 10
No one can guess what you have. Please post a 10-second sample from the source.
ok.
here comes a clip. as you can see the smoke is not smooth
https://dl.dropboxusercontent.com/u/14294986/smoke.mov -
It's the "trick" of the camera to get a brighter image when it's dark. I assume it has a very tiny sensor. It uses a very long exposure time and then a long "frame" is stored as about 14 fps. So about two real frames per second stored as 30.000/1001 which is about 29.97 fps -> progressive.
Yes I guess you are right. Is it possible to fix This in Adobe premiere?
2 fps are way too low for fixing this. But this is my opinion, maybe another one can help here, but don't expect miracles.
Its not possible to use some tool to simply remove the slow frames from the clip? Since its smoke it might not be noticed.
Any other tool to try? -
Hehe. Yes thats also an option.
But seriously. There is nothing worth trying? -
If you remove the duplicate frames, but keep the same frame rate , it will playback too fast (you wont see anything)
If you remove the duplicate frames, but decrease the frame rate, it will look almost the same as what you have now (looks almost like a slideshow)
You can try to "interpolate" or synthesis new "inbetween" frames, with something like after effects /timewarp/pixel motion or twixtor but it probably wont very good, and look "blobby" like morphing
The problem is you have too few actual unique frames, real data to work with
Ballet Dancer Needs Smooth Video Clip
By dancermom in forum Newbie / General discussionsReplies: 13Last Post: 30th Jun 2016, 11:58 -
Premiere CS6 - joining a clip and changing the duration
By giove in forum EditingReplies: 6Last Post: 16th Jan 2016, 03:12 -
How to import dpx. files to premiere as clip
By henry7121 in forum Newbie / General discussionsReplies: 4Last Post: 19th Dec 2015, 10:17 -
Removing bassy noise from audio clip with Adobe Audition
By sheilanagig in forum AudioReplies: 1Last Post: 31st Mar 2014, 17:08 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43
