Hello all,
I've read various guides on capturing VHS video but wanted some advice on best practice methods to capture, edit and author/encode my video.
From what I understand, the best way to capture VHS is using VirtualDUB and Huffyuv for lossless interlaced capture with YUV 4:2:2 as the colour space (please correct me if I'm wrong)
After capturing I would like to edit my video to tweak the colours, trim, combine and crop the clips then upscale using RedGiant Instant 4k to 1080p in Adobe Premiere Pro while retaining the video in the lossless format
Finally, I would like to author a DVD with menus and export into x264 lossy as well as x264 lossless formats
The problem that I find most confusing is that apparently Adobe Premiere and most video editing software work with RGB and will convert the YUV2 video. Is this something I should be concerned about and will it reduce the quality of my video? Can I do the above in Premiere and retain the Huffyuv lossless quality?
When authoring the DVD and other formats, will the colours need to be converted again and how will that impact the overall quality?
Thanks in advance
Yes, most A/D converters produce YCbCr (a.k.a. "YUV") output while most editing software operates in the more computing-oriented RGB space. There is a small loss converting from one to the other, but it pales in comparison to the artifacts inherent in VHS video. I wouldn't worry about it in your scenario.
What Hardware/Software Should I Use to Capture/Edit SD Video from VHS VCR?
By audioresearch in forum Capturing and VCRReplies: 10Last Post: 31st May 2016, 00:17 -
Capture card for VHS and coaxial (TV) / advice for VHS
By MrPeanut in forum Capturing and VCRReplies: 26Last Post: 25th Feb 2016, 00:06 -
Need advice about noise on VHS capture.
By S-VHS in forum Capturing and VCRReplies: 18Last Post: 14th Nov 2014, 09:16 -
video capture advice (recording vhs to computer file)
By ejl1789 in forum Capturing and VCRReplies: 7Last Post: 6th Oct 2014, 15:17 -
Editing VHS capture, advice on how to improve video.
By ricardouk in forum EditingReplies: 2Last Post: 22nd Apr 2014, 11:27
