Hey all,
I have some very large avi files. these were digital conversions from Hi 8 video tapes. I'd like to be able to go in and 'trim' the files, i.e. when they did the capture they just captured everything that was on the tape, so in some instances I have only 15 min of footage off of a 2 hr tape. The files sizes for the 2 hr capture are generally 24 gig so I have a vested interest in trying to shrink the size of the AVI file if there are portions of it that I don't need.
I have Edius Neo 3 and understand that I can do something that way, but that will not operate on the native AVI file, I'm looking for something that will let me change/edit the native AVI file.
Mark
virtualdub
make sure you set video=>direct stream copy , audio=>direct stream copy. You can mark in/ mark out a section and file=> save as avi and choose a location and different filename . That stream copies a section to keep . Original file will not be overwritten. If original file used I-frame only compression, you can cut anywhere arbitrarily. If it used temporal compression, you must cut on specific locations, keyframes. From that filesize, likely I-frame only compression . If you don't know, use mediainfo view=>text -
thanks for the info...
The compression is listed as "lossy" will that make a difference?
Which Video Software Editing Tool For 4k Rendering ?
By Sector in forum Newbie / General discussionsReplies: 2Last Post: 5th Aug 2015, 14:45 -
An editing tool that can trim by frame number
By loninappleton in forum EditingReplies: 4Last Post: 9th Nov 2014, 21:49 -
HELP: Does anyone know witch editing tool?
By vifblaa in forum Newbie / General discussionsReplies: 3Last Post: 19th Nov 2013, 12:18 -
please recommend tool for editing + adding audio track to video
By lovelove in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2011, 23:10 -
Blu ray disk files editing tool
By vertical in forum Blu-ray RippingReplies: 11Last Post: 28th Jul 2011, 08:34
