Hi, i want convert-optimize my podcasts mp4 o mvk files downloaded with Miro Player or Youtube-dl to mp4 files to be streaming with VLC Player without Activate Transcoding within VLC Player to save RAM, bandwitdth an playback quality and speed on playing.
The VLC default streaming settings are:
I tried match these settings with ffmpmpeg, but the streaming via UDP or RTP hangs. I have some other good files that have good streaming.Code::sout=#transcode{vcodec=h264,scale=0.75,acodec=mpga,ab=128,channels=2,samplerate=44100}:rtp{dst=192.168.1.100,port=5004,mux=ts} :sout-keep
and after, I triedCode:ffmpeg -hide_banner -i linuxactionshowep397-432p.mp4 -c:v libx264 -preset slow -crf 18 -c:a copy -pix_fmt yuv420p linuxactionshowep397-432p-002.mp4
Result = Bad Streaming, VLC Instance acts as server hangs after beggining playing.Code:ffmpeg -hide_banner -i linuxactionshowep397-432p-002.mp4 -movflags faststart -acodec copy -vcodec copy linuxactionshowep397-432p-003.mp4
End of question.
Other info collected from tests sample files:
Streaming-No-OK-Lavf56h264High(avc1)-aac(mp4a)-VLCHangs
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'linuxactionshowep397-432p.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf56.40.101
Duration: 01:31:15.84, start: 0.042667, bitrate: 466 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 768x432 [SAR 1:1 DAR 16:9], 330 kb/s, 30 fps, 30 tbr, 15360 tbn, 60 tbc (default)
Metadata:
handler_name : VideoHandler
Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default)
Metadata:
handler_name : SoundHandler
At least one output file must be specified
Streaming-No-OK-Lavf56h264High(____)-opus(____)-VideoOK-AudioNoOK
Input #0, matroska,webm, from '001-youtube-137_-_1080p_DASH_video.mkv':
Metadata:
COMPATIBLE_BRANDS: iso6avc1mp41
MAJOR_BRAND : dash
MINOR_VERSION : 0
ENCODER : Lavf56.36.100
Duration: 00:00:35.06, start: 0.007000, bitrate: 2065 kb/s
Stream #0:0(und): Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 1k tbn, 59.94 tbc (default)
Metadata:
CREATION_TIME : 2016-02-13 13:16:10
LANGUAGE : und
HANDLER_NAME : VideoHandler
Stream #0:1(eng): Audio: opus, 48000 Hz, stereo, fltp (default)
Streaming-OK-Lavf56h264Constrained Baseline(avc1)-aac(mp4a)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'ud_092815_449470_440.mp4':
Metadata:
major_brand : isom
minor_version : 512
encoder : Lavf56.15.102
Duration: 00:02:38.50, start: 0.000000, bitrate: 461 kb/s
Stream #0:0(eng): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p, 400x224 [SAR 1:1 DAR 25:14], 388 kb/s, 59.94 fps, 59.94 tbr, 11988 tbn, 119.88 tbc (default)
Metadata:
Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 22050 Hz, stereo, fltp, 39 kb/s (default)
Metadata:
Stream #0:2(und): Data: none (rtp / 0x20707472), 20 kb/s (default)
Metadata:
creation_time : 2015-09-28 20:33:11Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '01_01-Introduction To AutoCAD Electrical 2015.mp4':
Metadata:
major_brand : mp42
minor_version : 0
compatible_brands: mp42isomavc1
creation_time : 2014-03-31 14:12:12
compilation : 0
encoder : Sorenson Squeeze
comment : Encoded by
Duration: 00:01:31.60, start: 0.000000, bitrate: 289 kb/s
Stream #0:0(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, mono, fltp, 64 kb/s (default)
Metadata:
handler_name : soun
Stream #0:1(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1280x720, 220 kb/s, 15 fps, 15 tbr, 600 tbn, 30 tbc (default)
Metadata:
handler_name : vide
encoder : AVC Coding
Stream #0:2(und): Data: none (mp4s / 0x7334706D), 0 kb/s (default)
Metadata:
creation_time : 2014-03-31 14:12:13
handler_name : sdsm
Stream #0:3(und): Data: none (mp4s / 0x7334706D), 0 kb/s (default)
Metadata:
handler_name : odsm
Streaming-OK-Sorenson Squeezeh264(Main)-aac(mp4a)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '01_01-Introduction To AutoCAD.mp4':
Metadata:
major_brand : mp42
minor_version : 0
compilation : 0
Metadata:
handler_name : soun
Metadata:
handler_name : vide
Metadata:
handler_name : sdsm
Metadata:
handler_name : odsm
Thanks,
Results 1 to 1 of 1
What to use to convert files.. mkv to avi, mp4 to avi. etc
By Hollywood_12 in forum Video ConversionReplies: 6Last Post: 27th Jan 2015, 12:54 -
re_sync audio in MKV files using VLC?
By cottage in forum Video ConversionReplies: 3Last Post: 8th Dec 2014, 13:13 -
Convert H.264 MKV Files to MP4 Without Re-encoding
By pixel zombie in forum MacReplies: 10Last Post: 13th Nov 2013, 19:10 -
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 14:36 -
How do I convert mkv or mp4 files to burn a DVD?
By ibzomie in forum Video ConversionReplies: 3Last Post: 15th Sep 2012, 16:45
